Progress uses a defined font for each widgit (text field/browser/etc) on the
screen. These are defined at startup from an INI setting (Vantage.INI)
under the [fonts] section you have font##=........ You could edit the one
that is for the text field of the job, but it could have major impacts
across the whole Vantage. The other thing you could do is to use VB-Form
and setup a specific field that would contain your character text (in
courier or what ever font vantage has defined). Then setup you Crystal
traveler to print the text for that VBform field using your custom font.
Sent: Friday, October 03, 2003 9:00 AM
Subject: RE: [Vantage] Inserting inspection special characters
An example would be the true position character which is a circle with a
cross thru it or maximum material condition character which is an M with
a circle around it. I have installed special fonts on my workstation and
can create the symbols in notepad, but when I insert the file into the
job oper comment it reverts back to courier font.
Sent: Friday, October 03, 2003 8:14 AM
Can you give us an example of what type of special character?
Patrick Winter
Sent: Friday, October 03, 2003 8:05 AM
Subject: [Vantage] Inserting inspection special characters
Our production manager would like to have inspection special characters
printed on the router. Is there a way to insert special characters into
job operation comments and have them print on the router?
Kathy Schmidt
MIS Administrator
The Freeman Company
kathyschmidt@... <mailto:kathyschmidt@...>
Ph: 605-665-7456
Fx: 605-665-7882
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Patrick Winter
Kathy Schmidt
MIS Administrator
The Freeman Company
Ph: 605-665-7456
Fx: 605-665-7882
