I need to add about 7 new Price List Discount Codes (D35 - D41). I do not know how to use DMT or build BPMs yet, but I am quite adept at writing SQL to perform this function.
The data I need to bring into the LIVE environment is already in the TEST environment tables. Another person did this via DMT. Thus, I figured it would work with SQL.
I queried the tables I believe need the inserts & updates:
select Pl., plu.
from erp.pricelst pl inner join erp.pricelst_ud plu on pl.SysRowID = plu.ForeignSysRowID
where pl.ListType = ‘D’;
select * from erp.PriceLstGroups ;
select * from erp.CustomerDiscPriceLst;
select * from erp.PriceLstGroups;
Step 1: Insert the new discount codes into PriceLst from the TEST database:
Insert into erp.pricelst (Company, ListCode, CurrencyCode, ListDescription, StartDate, EndDate)
select Company, ListCode, CurrencyCode, ListDescription, StartDate, EndDate
from ERP10Test.erp.pricelst
where ListCode in (‘D35’,‘D36’,‘D37’,‘D38’,‘D39’,‘D40’,‘D41’);
Step 2: Insert the new Discount Codes into PriceLst_UD using SysRowID created in Step 1:
Insert into erp.pricelst_UD (ForeignSysRowID,Rebate_c)
select SysRowID, 0
from erp.pricelst
Step 3: Update the End Dates and the List Types:
Update erp.pricelst set listtype = ‘D’ where ListCode in (‘D35’,‘D36’,‘D37’,‘D38’,‘D39’,‘D40’,‘D41’);
Update erp.pricelst set EndDate = ‘2020-07-02’ where ListCode in (‘D17’,‘D25’,‘D30’,‘D31’,‘D33’,‘D34’);
Step 4: Insert new Discount Codes into PriceLstGroups from TEST (for product codes):
Insert into erp.PriceLstGroups (Company,ListCode,ProdCode,UOMCode)
select Company,ListCode,ProdCode,UOMCode -
from erp10test.erp.PriceLstGroups
where ListCode in (‘D35’,‘D36’,‘D37’,‘D38’,‘D39’,‘D40’);
Step 5: Run Update statements for the customers:
–update erp.CustomerDiscPriceLst set listcode = ‘D22’ where listcode = ‘D17’;
–update erp.CustomerDiscPriceLst set listcode = ‘D35’ where listcode = ‘D25’;
–update erp.CustomerDiscPriceLst set listcode = ‘D36’ where listcode = ‘D30’;
–update erp.CustomerDiscPriceLst set listcode = ‘D37’ where listcode = ‘D31’;
–update erp.CustomerDiscPriceLst set listcode = ‘D39’ where listcode = ‘D33’;
–update erp.CustomerDiscPriceLst set listcode = ‘D40’ where listcode = ‘D34’;
–update erp.CustomerDiscPriceLst set listcode = ‘D22’ where custnum IN (‘430’,‘553’,‘584’,‘784’,‘1057’,‘1415’,‘1500’,‘1880’,‘1602’);
Please advise if I missed something or that this cannot be done this way. I know Epicor Support frowns on the above. I promise to learn BPMs and DMT!
Thanks in advance.
Tony
