Could you use a variable to pass the pdf name to the graphic location formula in crystal? Maybe insert picture (blank picture space), click to format graphic, and then use formula builder on picture tab in Graphic location to pass the correct filename.
--- In vantage@yahoogroups.com, "Steve Bedilion" <sbedilion@...> wrote:
> Soooo....we have PDF prints for all our Parts. My users print the Job Travelers....then has to print the PDFs also. Has anyone been able to insert the PDF into the Traveler via Crystal and have it change to reflect the part.
> All my PDFs have uniform naming. M:\drawingname-Rev#.pdf
> I have a formula that prints out the exact UNC. And can Hyperlink correctly to it.
> I can insert a PDF, but I don't know if you can insert a PDF based on a formula. I think I got it to work once with JPGs....but that was over a year ago when i was playing around.
