Insite Manifest
they server the same function (shipping parcel/LTL) - but they are different add-on products
Hi,
I have been able to install insite Ver2.80.400 for Vantage 8.03.408. When I check the progress explorer the db is started. The port is 6190 everything seem fine. the appservers hows as running and port is 6290.
when I try to run Insite i get this error
Unable to find host mfgsys in file HOSTS or HOST file not found in expected location. (5193)
has anyone seen this before and do you know wha ti can do to fix this issue?
Larry
There's a special entry that needs to be put into the HOSTS file of the
local machine who is accessing the Manifest.
C:\WINDOWS\system32\drivers\etc
The file is in there, and I THINK this is the entry you need to put in,
although I can't find my notes from last time I set it up, with the
xxx.xxx.xxx.xxx being the IP address of your server.
xxx.xxx.xxx.xxx mfgsys
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Thursday, March 11, 2010 2:47 PM
Subject: [Vantage] Insite Manifest
> Hi,
> issue?
> Larry
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Is Insite Manifest the same thing as AgileShip Connect?
And is Insite Manifest the same as Ship connect?
Hi Jim,
InSite Software and Agile Network are two separate companies.
Ship Connect is an abbreviation of the name AgileShip Connect.
To clarify a little further, AgileShip Manifest is a full-featured, scalable enterprise transportation management system. AgileShip Connect provides the efficiency of transportation software without the expense and complexity of an AgileShip Manifest.
Richard Swallow
Agile Los Angeles
(424) 248-3093
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jim_chance@...
Sent: Thursday, February 20, 2014 2:10 PM
