BTW, we have this bug also on 9.05.607B.
Nancy
Nancy
Does anyone know what table the reason code goes into from the Inspection Processing form? It uses a view on the form, so I don't know where it comes from, or saves to. The screen shows that some of the data comes from the Nonconformance table, but the only reason code there is the one entered on the Nonconformance screen.
Thank you!
The table is the “Reason” table. Contains the field “ReasonCode” as well as “ReasonType”.
Hope this helps.
Carol
Thanks, but that isn't what I was looking for. I'm looking for the reason code that is attached to the specific rejection from inspection, that goes to a DMR. The DMR table has the reason when it is rejected in the DMR, and the Non Conform table has the one that puts it from stock (or whatever) to inspection. I can't find the table that holds the reason inspection rejected it.
Thank you!
<div id="ygrps-yiv-467669056yiv9894144820ygrp-text">
<div>You won’t…. I suggest writing a simple BPM to transfer it to a ShortChar field in the NonConf table when the transaction is completed, that’s what I had to do…
</div>
<div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-mkp #ygrps-yiv-467669056yiv9894144820hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-mkp #ygrps-yiv-467669056yiv9894144820ads {
margin-bottom:10px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-mkp .ygrps-yiv-467669056yiv9894144820ad {
padding:0 0;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-mkp .ygrps-yiv-467669056yiv9894144820ad p {
margin:0;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-mkp .ygrps-yiv-467669056yiv9894144820ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-sponsor #ygrps-yiv-467669056yiv9894144820ygrp-lc {
font-family:Arial;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-sponsor #ygrps-yiv-467669056yiv9894144820ygrp-lc #ygrps-yiv-467669056yiv9894144820hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-sponsor #ygrps-yiv-467669056yiv9894144820ygrp-lc .ygrps-yiv-467669056yiv9894144820ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820activity span {
font-weight:700;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820activity span span {
color:#ff7900;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820activity span .ygrps-yiv-467669056yiv9894144820underline {
text-decoration:underline;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 .ygrps-yiv-467669056yiv9894144820attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 .ygrps-yiv-467669056yiv9894144820attach div a {
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 .ygrps-yiv-467669056yiv9894144820attach img {
border:none;padding-right:5px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 .ygrps-yiv-467669056yiv9894144820attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 .ygrps-yiv-467669056yiv9894144820attach label a {
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 .ygrps-yiv-467669056yiv9894144820bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 .ygrps-yiv-467669056yiv9894144820bold a {
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 dd.ygrps-yiv-467669056yiv9894144820last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 dd.ygrps-yiv-467669056yiv9894144820last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 dd.ygrps-yiv-467669056yiv9894144820last p span.ygrps-yiv-467669056yiv9894144820yshortcuts {
margin-right:0;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 div.ygrps-yiv-467669056yiv9894144820attach-table div div a {
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 div.ygrps-yiv-467669056yiv9894144820attach-table {
width:400px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 div.ygrps-yiv-467669056yiv9894144820file-title a, #ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 div.ygrps-yiv-467669056yiv9894144820file-title a:active, #ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 div.ygrps-yiv-467669056yiv9894144820file-title a:hover, #ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 div.ygrps-yiv-467669056yiv9894144820file-title a:visited {
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 div.ygrps-yiv-467669056yiv9894144820photo-title a, #ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 div.ygrps-yiv-467669056yiv9894144820photo-title a:active, #ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 div.ygrps-yiv-467669056yiv9894144820photo-title a:hover, #ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 div.ygrps-yiv-467669056yiv9894144820photo-title a:visited {
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 div#ygrps-yiv-467669056yiv9894144820ygrp-mlmsg #ygrps-yiv-467669056yiv9894144820ygrp-msg p a span.ygrps-yiv-467669056yiv9894144820yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 .ygrps-yiv-467669056yiv9894144820green {
color:#628c2a;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 .ygrps-yiv-467669056yiv9894144820MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 o {
font-size:0;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820photos div {
float:left;width:72px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820reco-category {
font-size:77%;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820reco-desc {
font-size:77%;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 .ygrps-yiv-467669056yiv9894144820replbq {
margin:4px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-mlmsg select, #ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 input, #ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-mlmsg pre, #ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 code {
font:115% monospace;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-mlmsg #ygrps-yiv-467669056yiv9894144820logo {
padding-bottom:10px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-msg p#ygrps-yiv-467669056yiv9894144820attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-reco #ygrps-yiv-467669056yiv9894144820reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-sponsor #ygrps-yiv-467669056yiv9894144820ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-sponsor #ygrps-yiv-467669056yiv9894144820ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-sponsor #ygrps-yiv-467669056yiv9894144820ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-text {
font-family:Georgia;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-text tt {
font-size:120%;}
#ygrps-yiv-467669056 #ygrps-yiv-467669056yiv9894144820 #ygrps-yiv-467669056yiv9894144820ygrp-vital ul li:last-child {
border-right:none !important;}
On 8.03.4xx it is in the parttran record. Haven't specifically delved into that on 9.05.702a yet (but will next week after we do final conversion this weekend and go live.) Rob Brown |
Â
Rob Bucek Production Control Manager PH: (715) 284-5376 ext 311 Mobile: (715)896-4832 FAX: (715)284-4084 [cid:1.234354861@...]<http://www.dsmfg.com/> (Click the logo to view our site)<http://www.dsmfg.com/> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of whitenight922@... Sent: Wednesday, April 02, 2014 1:35 PM To: vantage@yahoogroups.com Subject: [Vantage] Re: Inspection Processing Thanks, but that isn't what I was looking for. I'm looking for the reason code that is attached to the specific rejection from inspection, that goes to a DMR. The DMR table has the reason when it is rejected in the DMR, and the Non Conform table has the one that puts it from stock (or whatever) to inspection. I can't find the table that holds the reason inspection rejected it. Thank you! [Non-text portions of this message have been removed]
Epicor told me (in version 905.701 at least), that Rob Bucek was correct. They confirmed that it doesn't save the inspection rejection reason code. I placed a call before he answered. It still seems weird to me that this data is entered, and not saved anywhere.
Thanks everyone!
Rob can you tell me about your BPM? Did you use Method or Directive, and which method or table did you use? I don't see a method that will work, and since it isn't saved to a table I don't think the data directive will work. I tried to put code behind the form but nothing I tried there seemed to work either. I even tried to code it to the save button, but it still wouldn't run my code.
Thanks for your help!
Just a heads up on a little bug we found in 702a. You can delete a nonconformance before it gets moved to DMR but it will be deleted from the nonconf table but not the parttran. Then the nonconf will get reused again and both of the nonconf IDs will post to your GL - throwing your inventory out of balance. Workaround is to not delete a nonconformance just reject it to DMR and accept it back there. Safer bet is to use process security to disable deleting a nonconformance.... especially since SCR#130672 was assigned but isn't even showing up in the SCR search yet.
Jenn
