Inspection Processing All or nothing (905.700C) - Now 9.05.702A
One thing I tried this morning and it wasn't that bad, no programming or customization required. I created a secondary "Inspection Warehouse/Bin". I "inspected" the entire quantity, "passing them from the normal inspection W/B to the secondary W/B. That eliminated the restraints of Inspection Processing. Then I used Inventory Transfer to partial inspect the parts form the secondary W/B to the Inventory W/B. I made notes in the reference field of Inventory Transfer that show up in Part Transaction History and document the trail. Not sure if this is what we are going with but at least it doesn't involve DMR.
On Monday, December 22, 2014 4:32 PM, "Miguel Santillan msantillan@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-134602611yiv4439740801ygrp-text">
  <div>
Also, how does you PO look.  I know if the PO goes to Insp Proc. Then the PO is open in TimePhase.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Monday, December 22, 2014 1:19 PM
Subject: Fw: [Vantage] Re: Inspection Processing All or nothing (905.700C) - Now 9.05.702A
Want to bring up same issue again - any new suggestions out there other than moving to DMR or adjusting PO lines?
Phil
< font id="yui_3_16_0_1_1419282568878_32670" face="Arial" size="2"> On Monday, January 7, 2013 10:25 PM, Greg Payne <gpayne@...> wrote:
Thanks to All.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mark Wagner
Sent: Monday, January 07, 2013 2:37 PM
Subject: Re: [Vantage] Re: Inspection Processing All or nothing 905.700C
Options Are:
Adjust your PO Line counts to match your per day inspection quantities (not ideal)
Fail everything to DMR from inspection processing. You can then fail certain quantities against the DMR
Sent: Monday, January 7, 2013 1:38 PM
Subject: [Vantage] Re: Inspection Processing All or nothing 905.700C
Hey Greg,
We were told by Epicor told no partial quantity inspections when we inquired (9.05.607b).
Interested to hear of workarounds others may have tried.
-David
David Sawan
Columbia Tech
--- In mailto:vantage%40yahoogroups.com, Greg Payne wrote:
> We receive 1000 parts in. The inspection team can inspect 100 per day and we need 100 a day going to the floor, but inspection processing makes us wait until all 1000 are complete to show the pass and failed amount.
> Is there a way to do partial quantities in inspection processing or what are the work arounds that you are using?
> Thanks for any suggestions.
> Greg Payne
> CONFIDENTIALITY NOTICE
> The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
> "This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior approval form the U.S. Department of State."
</div>
<div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801 -- #ygrps-yiv-134602611yiv4439740801ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-mkp #ygrps-yiv-134602611yiv4439740801hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-mkp #ygrps-yiv-134602611yiv4439740801ads {
margin-bottom:10px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-mkp .ygrps-yiv-134602611yiv4439740801ad {
padding:0 0;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-mkp .ygrps-yiv-134602611yiv4439740801ad p {
margin:0;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-mkp .ygrps-yiv-134602611yiv4439740801ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-sponsor #ygrps-yiv-134602611yiv4439740801ygrp-lc {
font-family:Arial;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-sponsor #ygrps-yiv-134602611yiv4439740801ygrp-lc #ygrps-yiv-134602611yiv4439740801hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-sponsor #ygrps-yiv-134602611yiv4439740801ygrp-lc .ygrps-yiv-134602611yiv4439740801ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801activity span {
font-weight:700;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801activity span span {
color:#ff7900;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801activity span .ygrps-yiv-134602611yiv4439740801underline {
text-decoration:underline;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 .ygrps-yiv-134602611yiv4439740801attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 .ygrps-yiv-134602611yiv4439740801attach div a {
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 .ygrps-yiv-134602611yiv4439740801attach img {
border:none;padding-right:5px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 .ygrps-yiv-134602611yiv4439740801attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 .ygrps-yiv-134602611yiv4439740801attach label a {
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 .ygrps-yiv-134602611yiv4439740801bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 .ygrps-yiv-134602611yiv4439740801bold a {
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 dd.ygrps-yiv-134602611yiv4439740801last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 dd.ygrps-yiv-134602611yiv4439740801last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 dd.ygrps-yiv-134602611yiv4439740801last p span.ygrps-yiv-134602611yiv4439740801yshortcuts {
margin-right:0;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 div.ygrps-yiv-134602611yiv4439740801attach-table div div a {
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 div.ygrps-yiv-134602611yiv4439740801attach-table {
width:400px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 div.ygrps-yiv-134602611yiv4439740801file-title a, #ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 div.ygrps-yiv-134602611yiv4439740801file-title a:active, #ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 div.ygrps-yiv-134602611yiv4439740801file-title a:hover, #ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 div.ygrps-yiv-134602611yiv4439740801file-title a:visited {
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 div.ygrps-yiv-134602611yiv4439740801photo-title a, #ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 div.ygrps-yiv-134602611yiv4439740801photo-title a:active, #ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 div.ygrps-yiv-134602611yiv4439740801photo-title a:hover, #ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 div.ygrps-yiv-134602611yiv4439740801photo-title a:visited {
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 div#ygrps-yiv-134602611yiv4439740801ygrp-mlmsg #ygrps-yiv-134602611yiv4439740801ygrp-msg p a span.ygrps-yiv-134602611yiv4439740801yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 .ygrps-yiv-134602611yiv4439740801green {
color:#628c2a;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 .ygrps-yiv-134602611yiv4439740801MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 o {
font-size:0;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801photos div {
float:left;width:72px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801reco-category {
font-size:77%;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801reco-desc {
font-size:77%;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 .ygrps-yiv-134602611yiv4439740801replbq {
margin:4px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-mlmsg select, #ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 input, #ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-mlmsg pre, #ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 code {
font:115% monospace;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-mlmsg #ygrps-yiv-134602611yiv4439740801logo {
padding-bottom:10px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-msg p#ygrps-yiv-134602611yiv4439740801attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-reco #ygrps-yiv-134602611yiv4439740801reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-sponsor #ygrps-yiv-134602611yiv4439740801ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-sponsor #ygrps-yiv-134602611yiv4439740801ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-sponsor #ygrps-yiv-134602611yiv4439740801ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-text {
font-family:Georgia;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-text tt {
font-size:120%;}
#ygrps-yiv-134602611 #ygrps-yiv-134602611yiv4439740801 #ygrps-yiv-134602611yiv4439740801ygrp-vital ul li:last-child {
border-right:none !important;}
Greg Payne
Hey Greg,
-David
David Sawan
Columbia Tech
> Greg Payne
Options Are:
Â
Â
Â
Hey Greg,
-David
David Sawan
Columbia Tech
> Greg Payne
You can receive the parts against the PO in batches. 1000 parts, ten receipts. The restriction is simply that the RCVDTL record must be processed together.
Sent: Monday, January 07, 2013 12:37 PM
Options Are:
From: davidsawan2000 davidsawan@...<mailto:davidsawan%40columbiatech.com>>
Hey Greg,
-David
David Sawan
Columbia Tech
> Greg Payne
Thanks to All.
Greg
Options Are:
Hey Greg,
-David
David Sawan
Columbia Tech
> Greg Payne
Phil
<div id="ygrps-yiv-2103546626yiv3978442269ygrp-text">
  <div id="ygrps-yiv-2103546626yui_3_16_0_1_1419282568878_32675">Thanks to All.<br>
Greg
Options Are:
Hey Greg,
-David
David Sawan
Columbia Tech
> Greg Payne
</div>
Question:  If you move them to DMR, you essentially fail them.  Then you can Pass or Fail again in DMR.  If you pass, good, it goes to inventory.  But if you Fail in DMR, doesn’t it go to scrap?
Miguel A. Santillan
Phil
Thanks to All.
Greg
Options Are:
Hey Greg,
-David
David Sawan
Columbia Tech
> Greg Payne
