Inspection Processing Customization
Hello,
I am working on a customization to replace the basic search of the Inspection Processing Form with my own quick search. I made a BAQ and quick search which I invoke in my customization and I am able to populate the form for all Tran Types accordingly except for RMAs. I am able to use the inspection processing adapter methods like GetFirstArtByID, GetReceiptByID, and Get ID to retrieve and update the form for PO Receipts, Inventory, Operation, Job Materials, and Subcontract, however, I can’t find a method to get RMAs. Anyone have any tips?
	private void InspectionProcessingEntryForm_BeforeToolClick(object sender, Ice.Lib.Framework.BeforeToolClickEventArgs args)
		if(args.Tool.Key == this.qsName)
			// Launch quick search
			object response = ProcessCaller.InvokeAdapterMethod(
					oTrans.EpiBaseForm,
					"QuickSearchAdapter",
					"ShowQuickSearchForm",
					new object[]{
						oTrans.EpiBaseForm,
						"InspProcQSv1",
						true,
						new DataTable()
			// User cancelled
			if (response == null) return;
			// Retrieve selected rows
			ArrayList list = (ArrayList)response;
			// Handle multi selections
			for(int i = 0; i <list.Count; i++)
				// The return val is a calculated field from the quick search BAQ which will contain the tran type and key fields based on the tran type.
				string returnVal = list[i].ToString();
				char delimiter = '|';
				string[] keyVals = returnVal.Split(delimiter);
				string tranType = keyVals[0];
				// Handle each tran type accordingly
				switch(tranType)
					case "PO Receipts":
						int vendorNum = int.Parse(keyVals[1]);
						string purPoint = keyVals[2];
						string packSlip = keyVals[3];
						int packLine = int.Parse(keyVals[4]);
						MessageBox.Show(string.Format("{0} {1} {2} {3}", vendorNum, purPoint, packSlip, packLine));
						inspProcAdapter.GetReceiptByID(vendorNum, purPoint, packSlip, packLine);
						oTrans.NotifyAll();
						break;
					case "Inventory":
					case "Operation":
					case "Job Materials":
					case "Subcontract":
						int tranID = int.Parse(keyVals[1]);
						inspProcAdapter.GetByID(tranID);
						oTrans.NotifyAll();
						break;
					case "First Articles":
						string jobNum = keyVals[1];
						int assemblySeq = int.Parse(keyVals[2]);
						int oprSeq = int.Parse(keyVals[3]);
						string resourceID = keyVals[4];
						int seqNum = int.Parse(keyVals[5]);
						inspProcAdapter.GetFirstArtByID(jobNum, assemblySeq, oprSeq, resourceID, seqNum);
						oTrans.NotifyAll();
						break;
					case "RMAs":
						int rmaNum = int.Parse(keyVals[1]);
						int rmaLine = int.Parse(keyVals[2]);
						int rmaReceipt = int.Parse(keyVals[3]);
						break;
					default:
						break;
