Inspection Required Not Checked on POs Generated from PO Suggest
Pam, not sure if this is possible, but check your company config file
and see if there are any settings there that need to be checked.
Under either Purchasing or the Quality Module.
Manasa
630.806.2000 x1515
Of pambro6225
Sent: Thursday, January 27, 2011 5:02 PM
Subject: [Vantage] Inspection Required Not Checked on POs Generated from
PO Suggestions
Has there been discussion, or has anyone been able to determine a
solution for this? When the Inspection Required checkbox is checked at
the Supplier level, and a PO is auto generated from a PO suggestion, the
Inspection Required checkbox is correctly checked on the PO. When the
Inspection Required checkbox is checked at the Part Class level, and a
PO is auto generated from a PO suggestion, the Inspection Required
checkbox is NOT checked on the PO. POs manually created for parts with
the Inspection Required checked at either the Supplier or Part Class
level results in the Inspection Required checkbox being correctly
checked on the PO. We are trying to correct this issue for Inspection
Required at the part Class level, and we also added custom code to add
the Inspection Required checkbox at the Part level, which works great
for PO entries manually created, but the Inspection Required checkbox
isn't checked on POs auto generated from a PO Suggestion. Thanks, Pam
Has there been discussion, or has anyone been able to determine a solution for this? When the Inspection Required checkbox is checked at the Supplier level, and a PO is auto generated from a PO suggestion, the Inspection Required checkbox is correctly checked on the PO. When the Inspection Required checkbox is checked at the Part Class level, and a PO is auto generated from a PO suggestion, the Inspection Required checkbox is NOT checked on the PO. POs manually created for parts with the Inspection Required checked at either the Supplier or Part Class level results in the Inspection Required checkbox being correctly checked on the PO. We are trying to correct this issue for Inspection Required at the part Class level, and we also added custom code to add the Inspection Required checkbox at the Part level, which works great for PO entries manually created, but the Inspection Required checkbox isn't checked on POs auto generated from a PO Suggestion. Thanks, Pam
