We are on E10 but came off maintenance before Windows 10 came out and to date have been unable to install E10 on windows 10 as it got itself in a knot about not having .net 4.5 -(windows 10 has 4.6 or 4.7). Cut a longs tory short, anyone else who may be in the same permission try the following - this was process was documented by Matthew Quinn from our IT partner, Innovec.
Install .NET 3.5 either:
// Enable .NET 3.5 install from DISM (component upgrades bypass WSUS)
Install .Net Framework 3.5 on Windows 8.1 & 10 with WSUS | KC's Blog// Install .NET 3.5 from DISM
DISM /Online /Enable-Feature /FeatureName:NetFx3 /AllOR
// Offline installer .NET 3.5
.Net Framework 3.5 offline Installer download | SourceForge.net -
Alter .NET release version reg keys
// Target key valueComputer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full\Version
// Take ownership and give yourself Full Control permissions
Edit “Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full” reg folder
Change owner from TrustedInstaller to yourself
Give yourself edit/full control permissions// Alter key “version”
From “4.7.02556” (or whatever it is) to “4.5” -
Reboot PC to load new reg key
Run E10 client installer
// Run installer from share
\nm-e10app\ERP10.0.700.4Deployment\ClientInstaller\E10Client.exe -
Revert registry/GPO settings where appropriate
// Change back reg key
From “4.5” (or whatever it is) to “4.7.02556” (or whatever it is)// Revert reg key permissions
Revoke full control permissions on the target reg key from yourself, make read only// Change owner back
Change owner of the reg key hub back to “NT SERVICE\TrustedInstaller” (Root for this user is the PC itself) -
Reboot PC to restore normalcy
Start Epicor Client
