Hello,
On a new test install of 10.2.100.7, the create Demo database failed on Task ID 410. The errors mention “A trigger returned a resultset and/or was running with SET NOCOUNT OFF while another outstanding result set was active”
This is a new install and there are no customization on the server. The application is on a clean (new) server. The database is going to a SQL Server that already has several E10.1.500 databases successfully running on it.
Have you seen this before or do you know a workaround?
Thank you,
Andy
