In summary,
1. On the server Map the same drive letter to the same server
share (Epicor) as you would on the client. (Even though it's on the
same server, it will allow you to map a drive to a share on the same
server)
2. Install the client the same way you do on a workstation using
the same mapped drive letter that you do on the client. Use the same
working directory you use on the client.
3. DO NOT install the progress network client as you do on the
workstation. (you don't need the progress network client since you are
on the server)
I have done this many times over on different versions of Vantage that
required a mapped drive letter and am successfully able to run the
client on the server.
Jerry W. Rodden
Staff Administrator
Production Planning
Cardington Yutaka Technologies Inc
Phone: 419-864-8777 ext. 6209
FAX: 419-864-7771
jrodden@...
server)
on the server)
Jerry W. Rodden
Staff Administrator
Production Planning
FAX: 419-864-7771
jrodden@...
