>If you follow the installation instructions by Epicor to the
> Is there anyone who had installed Vantage on Linux?
> We had installed Vantage on Linux successfully. However, there is a
> critical security issue. Under Linux, database is accessed through a
> public folder shared by Vantage clients.
> Different from Windows, Linux folder sharing setting has only read only
> and full access. That mean, allowing user to access the database also
> allow him to delete the database.
letter, you will be sharing both the Progress Linux software
and the Progress Linux database through samba.
This, of course, makes no sense at all. You can install all the
Linux stuff elsewhere; it does not have to be shared at all.
Windows clients should always access the database through the
Progress client-server protocol, which does not require
physical access to the database at all.
In fact, Windows clients can't even access the database
physically, until it is converted to a Windows structure
using prostrct repair.
In Vantage 8, Windows clients will not be able to access
a Linux Progress database at all (physically, that is).
It would have to be dumped on Linux and loaded on Windows.
But in Vantage 8, Windows clients will not even require
Progress at all, so this is even less of a problem.
Pim
