Installation Error
I get System.InvalidOperationException: 7-zip invocation failed when installing Epicor Kinetic. I disable the antivirus and run it as administrator, but nothing seems to make it work.
This is the whole error message:
System.InvalidOperationException: 7-zip invocation failed:
ERROR: CRC Failed : Erp.Contracts.BO.SalesOrdHedDtl.dll
ERROR: CRC Failed : Erp.UI.PeriodicitySuppEntry.dll
ERROR: CRC Failed : Microsoft.CodeAnalysis.CSharp.dll
ERROR: CRC Failed : Microsoft.ReportViewer.Common.dll
ERROR: CRC Failed : syncfusion.shared.base.xml
at Epicor.ISV.ClientInstaller.Services.SevenZipCaller.ReportInvocationFailure(String error)
at Epicor.ISV.ClientInstaller.Services.SevenZipCaller.RunCommand(String arguments)
at Epicor.ISV.ClientInstaller.Services.SevenZipCaller.ExtractArchiveToDirectory(String directoryPath, String archivePath, String tempDirectory)
at Epicor.ISV.ClientInstaller.Services.ExtractReleaseClientFiles.ExtractReleaseClientToTempDirectory(String targetLocation, String tempDirectory)
at Epicor.ISV.ClientInstaller.Services.ExtractReleaseClientFiles.ExtractReleaseClientZip()
at Epicor.ISV.ClientInstaller.Services.InstallerController.DownloadClientFiles()
at Epicor.ISV.ClientInstaller.Services.InstallerController.InstallClient()
at Epicor.ISV.ClientInstaller.Services.InstallWindowController.ExecuteInstallation()
CRC issues indicates you have a bad zip. Delete it, redownload.
I did that a couple of times, and same error persist.
Are you unzipping the entire thing (and mounting it, if its a base release)?
I am using Epicor Client Installer. The installer runs everything automatically.
Ah i was thinking server side. Still CRC error usually indicates a bad file. It’s not beyond the realm of possibility that file is corrupt at the source. Perhaps you can get a guinea pig to download the same file and attempt to install.
What URL are you downloading the installer from? Kinetic Client Installer Downloader?
Yes, that is where I am getting the installer.
Odd we just downloaded a copy ourselves today and it’s working.
