Installing 5.0
Patrick, what I've done in the past is zip up an entire folder to a file and
then remove the contents. After I'm done doing what I needed to do I go
back in and unzip the file back to the directory. This doesn't help with
registry entries being changed. By marking a directory "No Access", some
programs may want to go to that directory to install and then will have
problems because they can't do anything with the directory. I haven't tried
this with 5.0.
Just an idea,
Ted Kitch
ted@...
Sent: Wednesday, June 06, 2001 7:18 AM
To: Vantage User Group on Onelist (E-mail)
Subject: [Vantage] Installing 5.0
To any NT guru's
Would it be wise when installing 5.0 on the server next to version 4.0 to
first unshare the 4.0 epicor folder, then mark it "NoAccess" to block out
any searching in this area? It seems like when installing any new version of
progress it wants to find an old version to install over, also it always
seems like something ends up pointing from the new version to the old like
the database it's self which happened to me. Also when installing the client
would it be wise to unmap the old drive to the Epicor folder, map the new
drive to epic50, install 5.0 & test, then unmap the epic50 folder, map &
test version 4 again, then test both. This is how I installed my clients, it
seemed to help.
Patrick Winter
sSc Specialty Screw Corporation
Vantage 5.00.317, Progress 9.1a
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=190462.1393721.2979173.2/D=egroupmail/S=1700007183:N/
A=551015/?http://www.debticated.com> www.debticated.com
<http://us.adserver.yahoo.com/l?M=190462.1393721.2979173.2/D=egroupmail/S=17
00007183:N/A=551015/rand=198719713>
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
To any NT guru's
seemed to help.
Patrick Winter
I wish you had suggested these things about a month ago. I installed a patch using the default 3.0 path instead of 4.0 and screwed everything up for a long time.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Wednesday, June 06, 2001 8:17 AM
To any NT guru's
seemed to help.
Patrick Winter
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
