I believe that DB that is in there is bad...the manager manager user
name doesn't work...you should take a back-up of your current one and
restore it, or something of the like.
Paul
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of jonnyfatman666
Sent: Tuesday, January 09, 2007 10:14 AM
To:
Subject: [Vantage] Re: Installing 803 pitfalls
Just installed it now. Rebooted just to make sure.
Tried to start training DB for 803.
DB starts OK.
Main appserver starts OK
ProcessServer stays on 'STARTING' for ages, then changes to 'ACTIVE'
TaskAgent starts OK and is 'ACTIVE' with an 'AVAILABLE' status. I
believe this should be 'CONNECTED' instead.
I don't seem to be able to log in using the client software, and
would like to know if there are any settings to check.
This is the only error in the MfgTrain803ProcessServer log:
[07/01/09@13:20:57.966+0000] P-003792 T-002252 1 AS --
(Procedure: 'agent/startup.p' Line:613) Connection failure for host
localhost port 8307 transport TCP. (9407)
(Procedure: 'agent/startup.p' Line:613) Application server connect
failure. (5468)
(Procedure: 'agent/startup.p' Line:615) AppServer Connection
Failure: -URL AppServerDC://localhost:8307
Any ideas?
Cheers,
Jonny
--- In
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
"bw2868bond" <bwalker@...> wrote:
> The Vantage 8.03 DVD I was sent, installed alongside 8.00 without a
> hitch. Appserver ports were preconfigured.
> Bernie.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
"jonnyfatman666"
> <jonathan.waines@> wrote:
> > Hi All,
> > Are there any pitfalls I should be aware of before installing
803?
> I
> > have 809G installed at the moment on my test server but I'll be
> > installing over the top of it, so that both versions will be on
the
> > same machine.
> > Will the appservers automagically work for the new DB or will I
> have to
> > fiddle about with port numbers etc?
> > Cheers,
> > Jonny
