Installing a Menu Customization
Not sure I follow you
If you created a customization then putting it in menu maintenance should
be enough.
If you want o make sure it ALWAYS gets called then doing Process Calling
Maintenance and setting the Called From Blank will take care of it.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Wed, Feb 20, 2013 at 9:48 AM, Bruce <work@...> wrote:
> Hi,
> I am in 9.05.605
> I have created a customization on the detail page of the Container Landed
> Cost Entry menu.
> I loaded the customization in Menu Maintenance and created a subprocess as
> well.
> Unfortunately, I do not know what Called Process Reference I should use in
> Process Calling Maintenance. I loaded the list, but
> Epicor.Mfg.UI.ContainerShipmentEntry was not listed
> Can anymore tell me how to find the Called Process Reference?
> Thanks!
Hi,
I am in 9.05.605
I have created a customization on the detail page of the Container Landed Cost Entry menu.
I loaded the customization in Menu Maintenance and created a subprocess as well.
Unfortunately, I do not know what Called Process Reference I should use in Process Calling Maintenance. I loaded the list, but Epicor.Mfg.UI.ContainerShipmentEntry was not listed
Thanks!
