Installing SonicMQ
It turns out my issues was because SonicMQ was already installed.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Of Zac Jason Woodward
Sent: Thursday, May 12, 2011 6:30 PM
Subject: Re: [Vantage] Re: Installing SonicMQ
The sonic install disc has what you need to create the service, the
parameters need to be changed to reflect your environment. In addition
if running server 2008 set the service up as a delayed start.
Sent from my Verizon Wireless 4GLTE smartphone
----- Reply message -----
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Subject: [Vantage] Re: Installing SonicMQ
Date: Thu, May 12, 2011 2:22 pm
I just went through this install. I had to stop openedge when i was
getting the same error messages.
After the install, you will want to setup SonicMQ to run as a service.
You should be able to google it to find the documentation, but it has to
be done at the command prompt. I seemed crazy to me that it is not a
service by default and there is no option to make it a service. For
testing, you can just start the DomainManager manually.
Scott
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Joe
Rojas <jrojas@...> wrote:
> Hi Zac,
> I tried to install SonicMQ and it is telling me that "The file
> D:\Progress\oe101c\java\SonicMQ\lib\activation.jar is in use".
> Should OpenEdge be shut down before I install SonicMQ?
> dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191 jrojas@...
> and flooring
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On
> Behalf Of Zac Jason Woodward
> Sent: Thursday, May 12, 2011 1:03 PM
> Subject: Re: [Vantage] Installing SonicMQ
> Correct
> From: "Joe Rojas" <jrojas@...>
> To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>"
> <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
> Subject: [Vantage] Installing SonicMQ
> Date: Thu, May 12, 2011 10:49 am
> Hi Zac.
> Thanks for the reply!
> Just to clarify, when you say " Sonic is on db server" do you mean the
> server that has OpenEdge installed on it?
> jrojas@...<mailto:jrojas%40matsinc.com> | www.matsinc.com Ask us about
> From:
> vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vanta
> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mail
> to:vantage%40yahoogroups.com>] On Behalf Of Zac Jason Woodward
> Sent: Thursday, May 12, 2011 12:47 PM
> To:
> Sonic is on db server.
> Without security unless its going over the internet.
> Replication on separate sql server so it doesn't impact performance.
> We have it installed and working. Give me a call if you would like.
> 435-820-6515
> From: "Joe Rojas" <jrojas@...<mailto:jrojas%40matsinc.com>>
> To:
"vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantag
> <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vant
> Date: Thu, May 12, 2011 10:38 am
> Hello,
> I recently ordered Replication Server and I'm looking to install it.
> As a prerequisite, I need to install SonicMQ.
> The instructions for installing Replication Server make it a point to
> suggest that it's best to install it on a server other than the Epicor
> server.
> But with SonicMQ, it doesn't make a suggestion either way.
> Should I install this on the Replication server or does this need to
> be installed on the Epicor server?
> Also, what is the opinion of installing with or without security
> enabled?
> Thanks!
> jrojas@...<mailto:jrojas%40matsinc.com><mailto:jrojas%40matsinc.
> com> | www.matsinc.com Ask us about our clean, green and beautiful
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Hello,
server.
Should I install this on the Replication server or does this need to be
enabled?
Thanks!
435-820-6515
Hello,
server.
enabled?
Thanks!
jrojas@...<mailto:jrojas%40matsinc.com> | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
Hi Zac.
435-820-6515
Hello,
server.
enabled?
Thanks!
Correct
Hi Zac.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
435-820-6515
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Hello,
server.
enabled?
Thanks!
jrojas@...<mailto:jrojas%40matsinc.com><mailto:jrojas%40matsinc.com> | www.matsinc.com Ask us
Hi Zac,
Correct
Hi Zac.
435-820-6515
Hello,
server.
enabled?
Thanks!
I just went through this install. I had to stop openedge when i was getting the same error messages.
After the install, you will want to setup SonicMQ to run as a service. You should be able to google it to find the documentation, but it has to be done at the command prompt. I seemed crazy to me that it is not a service by default and there is no option to make it a service. For testing, you can just start the DomainManager manually.
Scott
--- In vantage@yahoogroups.com, Joe Rojas <jrojas@...> wrote:
> Hi Zac,
> Correct
> Hi Zac.
> 435-820-6515
> Hello,
> server.
> enabled?
> Thanks!
The sonic install disc has what you need to create the service, the parameters need to be changed to reflect your environment. In addition if running server 2008 set the service up as a delayed start.
Scott
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Joe Rojas <jrojas@...> wrote:
> Hi Zac,
> Correct
> Hi Zac.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> 435-820-6515
> To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>"
> <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>>
> Hello,
> server.
> enabled?
> Thanks!
