Intercompany Ordering System
Hello All,
We have recently added another company to our epicor so we are able to see there stock etc we have something in place where we have minimum and maximum stock levels we then re-order to make goods from the new company we have added but we want to get something automated so for example if the max is 20 and we have 2 on hand aslong as the other company on our epicor has stock order 18 from them to get the stock levels up hope this is enough details
Not sure if intercompany is an extra module. Do you have these screens available?
Hello yes the situation we have is one company here in UK and one in poland both on out epicor under ELST01 and ELST02 we have a section in the part master we made called re-order min and max and ideally our on hand needs to most the time be at the max level
we want epicor to then generate a PO as long as ELST02 have stock
@pompe4040 - You could set it up so ELST01 has it as a purchased part form ELST02, and creates a PO Suggestion. Your buyer accepts the suggestion, Epicor runs the multicompany server processes, the demand Sales Order is created in ELST02 to sell it to ELST01, and then it’s shipped. Lots of steps, but you could probably automate some of it.
Hello this is how currently all the parts are set up as we buy them from the supplier directly and we then either have them go to ELST02 then we order from there ?
this is how one part is set up
this is how its currently set up as ELST02 - being ELST04 and a supplier
but we want it to do the same as this but then to only suggest the re-order to max as long as the ELST02 company has enough stock to cover it
