I'd say you hit the nail on the head! What I don't understand is why
this would happen with the InvceHead table. I thought this table
would only be written once for each order invoiced, regardless of
the order size. Then the InvoiceDtl table would have the data for
each line/release. This obviously isn't true, but I'd like to know
why it isn't true! :)
Ron Cole
IT Manager, IED Inc.
rcole@...
--- In vantage@yahoogroups.com, "Podlin, Michael"
<michael.podlin@v...> wrote:
recommend that you only select specific fields to watch (not select
all). Also makes the database grow rather quickly too.
access. )
Ron Cole
rcole@...
>that it went beyond the 1000 char limit set on them? Epicor does
> Is it possible that "any changes" dumped so much into the log file
>Behalf
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On
> Of swinky68table.
> Sent: Thursday, January 26, 2006 4:17 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Interesting BAM problem
> Actually, there wasn't any custom code on my part. All I had done
> was set the BAM to keep a log of any changes to the InvceHead
> When we tried to invoice the order, the Server Log recorded thiswrote:
> error: [06/01/24@16:08:35.541-0500] P-005876 T-005796 1 AS --
> (Procedure:
> 'db/trg/InvcHead/WRITE.P' Line:3198) ** Attempt to expand record
> beyond the maximum allowed size. (444)
> Who knows what would have happened if I'd asked for emails to be
> sent as well!
> Ron Cole
> rcole@i...
> --- In vantage@yahoogroups.com, "Lepley, Scott A." <sal@m...>
> > Yeah, really scary. Ron, would you mind posting the criminal :-
> BAM alertinvoiced.
> > code?
> > Regards,
> > Scott
> > From: RICH WAGNER [mailto:rwagner@b...]
> > Sent: Thursday, January 26, 2006 4:42 PM
> > Subject: RE: [Vantage] Interesting BAM problem
> > Scary
> > From: swinky68 [mailto:rcole@i...]
> > Subject: [Vantage] Interesting BAM problem
> > Hi all,
> > An FYI tidbit I wanted to pass along to the list...
> > I had a problem where a fairly large order could not be
> > Every time it was brought into Invoice Entry, Vantage would hangin
> and
> > have to be shut down. I opened a support ticket on this 2 days
> ago. I
> > got a message from support this morning to check for any alerts
> > BAM. Turns out that I had an alert set to monitor the InvceHeadWHY
> table
> > and this was causing the problem. Once I turned off the alert,
> > everything ran fine again. I did not get an explanation as to
> thisknowledge
> > was causing the problem, but I thought I would share the
> > with everyone here.must have already linked your email address to a yahoo id to enable
> > Thanks,
> > Ron Cole
> > rcole@i...
access. )
> (1) To access the Files Section of our Yahoo!Group for ReportBuilder and Crystal Reports and other 'goodies', please goto:
> (2) To search through old msg's goto:http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto:http://groups.yahoo.com/group/vantage/links
> Yahoo! Groups Links
