Thank you Mr. James.
I will start with adjusting the scaling to see how that works.
Thanks for the tip,
DaveO
Thanks for the tip,
DaveO
We have an Intermec CK71 Handheld computer and we are having a scaling issue with the Epicor application.
We setup a Terminal Server to run the Epicor HandHeld interface. That works fine when we login from the server.
We configured the Intermec RemoteDesktop application to login to our Terminal server and everything works. However the login and application windows are waaaaaaay to small to be used on the Intermec handheld.
I tried many combinations of the "Use Full Screen" and "Fit Remote Desktop to screen" and none seem to be doing the trick.
I have two scanners and one was working fine and the other had this scaling issue. I downloaded and updated the firmware on both scanners and now BOTH have the scaling issue. Aaaaaaarg!
Has anyone battled with this issue in the past?
Thanks for any help.
Dave Olender (DaveO)
Ph: 651-246-3281
You might already be doing this, but we have the CK71 scanners here too, and we use the actual handheld screen of epicor. All you need is a -HH. It should look like this for your application icon.
C:\Epicor\ERP10.0Client\Client\Epicor.exe /config=Epicor10.sysconfig -HH
As to the scaling if its just scaling in Epicor then most likely its a setting with a theme or something. Go into the sysconfig file and try setting it back to default and see if that helps. If it does then you know something has been changed.
