Inv Adjustment w $ Value
It depends on if you are talking price or cost. Either way you will have to write 4gl code in a BPM or VB code in a customization with a foreign key view to the additional table(s) you need. You could get the price from the Part table and the Cost from the PartCost table. I haven't tackled this particular issue, but I think you will have your work cut out for you.
Sent: Fri, December 18, 2009 12:23:23 PM
Subject: [Vantage] Inv Adjustment w $ Value
Â
Before I tackle this I thought I check with the group. I want to raise an exception when inventory gets adjusted under or below a dollar amount. The trick is not allowing the user to proceed with the transaction and allowing the supervisor to update. The problem I run into is that no where on the Qty Adj screen there is a dollar value associated with part. Any ideas?
