Invalid Values in Service Connect
Sal,
Try using the BAQ writer to see what is in there for current data -
values should be the same...I think you need to capitalize if needed or
use all small letters if not needed also...
The purchasing factor may need to be >>,>>9.9999 as shown in the data
dictionary (version 408a) and may need to be 1 or greater (not sure if
that is required or if 1 is the default)?
Karen
Of idiabos
Sent: Thursday, August 20, 2009 11:32 AM
Subject: [Vantage] Re: Invalid Values in Service Connect
That's the strange thing, I have the word true as the value for the
NonStock field and for the decimal fields I have the number 0.00. Not
sure why it isn't accepting these values.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Rob
Bucek" <rbucek@...> wrote:
> What type of value are you passing for your nonstock field? Yes/no,
> 0/1, true/false?
> Rob Bucek
> Manufacturing Engineer
> PH: (715) 284-5376 ext 3111
> FAX: (715)284-4084
> <http://www.dsmfg.com/>
> (Click the logo to view our site) <http://www.dsmfg.com/>
Behalf
> Of idiabos
> Sent: Thursday, August 20, 2009 10:30 AM
> Subject: [Vantage] Invalid Values in Service Connect
> Hello,
> Does anyone know what I am doing wrong here. I have a simple Service
> Connect workflow that uploads data into the Part Master. When I
attempt
> to run the routine I receive the error below on all the fields. The
> value of each field looks valid. I am importing via an excel
> spreadsheet. Thanks!!!
> The 'NonStock' element is invalid - The value '' is invalid according
to
> its datatype 'http://www.w3.org/2001/XMLSchema:boolean' - The string
> is not a valid Boolean value.
> The 'PurchasingFactor' element is invalid - The value '' is invalid
> according to its datatype 'http://www.w3.org/2001/XMLSchema:decimal' -
> The string '' is not a valid Decimal value.
> -Sal
Hello,
Does anyone know what I am doing wrong here. I have a simple Service Connect workflow that uploads data into the Part Master. When I attempt to run the routine I receive the error below on all the fields. The value of each field looks valid. I am importing via an excel spreadsheet. Thanks!!!
The 'NonStock' element is invalid - The value '' is invalid according to its datatype 'http://www.w3.org/2001/XMLSchema:boolean' - The string '' is not a valid Boolean value.
The 'PurchasingFactor' element is invalid - The value '' is invalid according to its datatype 'http://www.w3.org/2001/XMLSchema:decimal' - The string '' is not a valid Decimal value.
-Sal
It looks like you need to have some data in those fields. Boolean must
either be true or false. Can't be blank. Same goes for the decimal
field. I would enter 0.00 if that is what should be there. Any number
field must have a value also( 0 for example).
Of idiabos
Hello,
-Sal
0/1, true/false?
Rob Bucek
FAX: (715)284-4084
Of idiabos
Hello,
-Sal
That's the strange thing, I have the word true as the value for the NonStock field and for the decimal fields I have the number 0.00. Not sure why it isn't accepting these values.
> 0/1, true/false?
> Rob Bucek
> FAX: (715)284-4084
> Of idiabos
> Hello,
> -Sal
is it true or True?
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of idiabos
Sent: Thursday, August 20, 2009 12:32 PM
> 0/1, true/false?
> Rob Bucek
> FAX: (715)284-4084
Behalf
> Of idiabos
> Hello,
attempt
to
> -Sal
It's "true" (w/o the quotes).
--- In vantage@yahoogroups.com, "Blake Clemens" <blake.clemens@...> wrote:
> is it true or True?
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
> Of idiabos
> > 0/1, true/false?
> > Rob Bucek
> > FAX: (715)284-4084
> Behalf
> > Of idiabos
> > Hello,
> attempt
> to
> > -Sal
Do all of your inputs match your trace? Did you set RowMod to U?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of idiabos
Sent: Thursday, August 20, 2009 12:38 PM
> is it true or True?
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of idiabos
> > 0/1, true/false?
> > Rob Bucek
> > FAX: (715)284-4084
> Behalf
> > Of idiabos
> > Hello,
> attempt
according
> to
> > -Sal
Dump the quotes
Rob Bucek
FAX: (715)284-4084
Of idiabos
Sent: Thursday, August 20, 2009 11:38 AM
> is it true or True?
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of idiabos
> > 0/1, true/false?
> > Rob Bucek
> > FAX: (715)284-4084
> Behalf
> > Of idiabos
> > Hello,
> attempt
according
> to
> > -Sal
I am not sure Blake. Where do I go to check? Forgive me I am a newbie. Thanks!!
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
> Of idiabos
> "Blake Clemens" <blake.clemens@> wrote:
> > is it true or True?
> > Thanks,
> > Blake Clemens
> > IT Systems Engineer
> > (800) 360-2364 x132
> Behalf
> > Of idiabos
> > > 0/1, true/false?
> > > Rob Bucek
> > > FAX: (715)284-4084
> > Behalf
> > > Of idiabos
> > > Hello,
> > attempt
> according
> > to
> > > -Sal
Usually I trace my steps in Vantage using the "Trace" feature. Then you
view the trace with your XML Notepad or what ever you use to view your
XMLs. This will give you a list of what Webservices are being used and
what information is being passed through each of them.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of idiabos
Sent: Thursday, August 20, 2009 12:48 PM
Thanks!!
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of idiabos
> > is it true or True?
> > Thanks,
> > Blake Clemens
> > IT Systems Engineer
> > (800) 360-2364 x132
> Behalf
> > Of idiabos
Not
Yes/no,
> > > 0/1, true/false?
> > > Rob Bucek
> > > FAX: (715)284-4084
> > Behalf
> > > Of idiabos
> > > Hello,
Service
> > attempt
The
> according
> > to
string
invalid
> > > -Sal
