Inventory Problems
Any commonality to the Parts that added, Purchased or Manufactured? Stock or
Non-Stock? Is it in a Bin that is marked Not Nettable?
Were they entered against the proper Tag, or if a Blank Tag was used because
it was in a different Bin then was the original Tag zero'd out.
Did you run the Returned \ Voided Tag Report to make sure everything was
entered?
Scott
quest_erp
Sent: Tuesday, January 08, 2008 1:20 PM
Subject: [Vantage] Re: Inventory Problems
Oops, my bad...the term roll-up was used here(this company)however I
have
always and Vantage labels this process as post.
Yes we did the procedure you detailed.
I should also that it was only a percentage of the parts that added
instead of overriding with the new count. Looks like about 15% but
the audit is still ongoing.
--- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@...>
wrote:
> What do you mean by Roll-Up? Do you mean when it was Posted?
> Did you go through the Procedure of creating the Count Group,
Generate Tags,
> Enter Count against those Tags, Confirm and Fix any Variances and
then Post?
> Scott
Behalf Of
> quest_erp
> Sent: Tuesday, January 08, 2008 10:34 AM
> Subject: [Vantage] Inventory Problems
> We just did a full Physical Inventory for year end. This is the
first
> time I have been involved with a pure by the book Vantage
Inventory.
> (I have always extracted the count sheets and made the adjustments
> manually via Quantity Adjustment). The problem started when we did
the
> roll-up. The roll up added the counted quantity from the count
sheets
> to the pre-inventory quantity. So if Stock Status Report showed 10
> parts at inventory start and the count tag showed 5 actual parts
when
> the roll up was performed the Stock Status Report now shows 15
parts
> in stock instead of 5. Does anyone know what went wrong? The folks
> here insist that this is the way they have always done it here and
> this is a new problem. We are on version 8.03.305i
> Kirk Miller
> ERP Analyst
> Quest Aircraft Company
> E: kmiller@...
must have
Builder and
> Yahoo! Groups Links
Yahoo! Groups Links
We just did a full Physical Inventory for year end. This is the first
time I have been involved with a pure by the book Vantage Inventory.
manually via Quantity Adjustment). The problem started when we did the
roll-up. The roll up added the counted quantity from the count sheets
parts at inventory start and the count tag showed 5 actual parts when
the roll up was performed the Stock Status Report now shows 15 parts
Kirk Miller
ERP Analyst
E: kmiller@...
Did you go through the Procedure of creating the Count Group, Generate Tags,
Enter Count against those Tags, Confirm and Fix any Variances and then Post?
Scott
quest_erp
Kirk Miller
ERP Analyst
E: kmiller@...
Yahoo! Groups Links
Scott's right. If you create a Count Group, it will freeze the current
inventory values and then only post the difference between the two counts. Did
you jump the gun on the Start Count? Did you do it after all transactions were
entered before the count?
Mark W.
have
Generate Tags,
then Post?
> Scott
Behalf Of
> quest_erp
first
Inventory.
the
sheets
when
parts
> Kirk Miller
> ERP Analyst
> E: kmiller@...
must have
Builder and
> Yahoo! Groups Links
