It runs one called presetinventoryadj I added this one and I'm still getting
the same result.
~Charlie
_____
bw2868bond
Sent: Friday, February 20, 2009 10:33 AM
Subject: [Vantage] Re: Inventory Qty Adj SC
I believe if you trace a inv adjust transaction in the UI you will
find it calls get new inv adjust (or something like that) to get a
blank dataset to work with.
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Charlie
Wilson" <foamdesigncsw@...>
wrote:
Checked by AVG - www.avg.com
Version: 8.0.237 / Virus Database: 270.10.23/1951 - Release Date: 02/20/09
07:26:00
the same result.
~Charlie
_____
bw2868bond
wrote:
>taken
> All,
> I'm working on a SC to adj a bunch of parts qty down to zero.
> I have an excel sheet with the part number and qty that needs to be
> away from the part to adjust it to zero.amount.
> In the SC I first confirm that the part exsist
> Then get the inventory of that part and then adj the qty down that
>does not
> When I run the flow it tells me that the ttinventoryqtyadj record
> exist. Can some one point me to what may be causing this error.No virus found in this incoming message.
> Charlie
07:26:00
