Invoice Aging Current fiscal record cannot be found
Folks are getting the following error when selecting the Invoice Aging button on the Supplier Tracker form.
This is an established system so I would think the fiscal record is there. Any ideas on what is going on?
Business Layer Exception
Current Fiscal record cannot be found.
Error Detail
Description:  Current Fiscal record cannot be found.
Program:  Erp.Services.BO.APAgingTracker.dll
Method:  GenerateTracker
Line Number:  169
Column Number:  17
Table:  FiscalPer
Server Trace Stack:     at Erp.Services.BO.APAgingTrackerSvc.GenerateTracker(String supplierID) in c:\_Releases\ERP\RL10.2.200.0\Source\Server\Services\BO\APAgingTracker\APAgingTracker.cs:line 169
   at Erp.Services.BO.APAgingTrackerSvcFacade.GenerateTracker(String supplierID) in c:\_Releases\ERP\RL10.2.200.0\Source\Server\Services\BO\APAgingTracker\APAgingTrackerSvcFacade.cs:line 65
   at SyncInvokeGenerateTracker(Object , Object[] , Object[] )
   at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
   at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func`2 func) in C:\_Releases\ICE\ICE3.2.200.10\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
   at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in C:\_Releases\ICE\ICE3.2.200.10\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
   at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:\_Releases\ICE\ICE3.2.200.10\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
   at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
   at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
   at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
   at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
   at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
   at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
   at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
   at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
   at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
   at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
   at System.ServiceModel.Channels.SecurityChannelListener`1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
   at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
   at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
   at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
   at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
   at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
   at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
   at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
   at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
   at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
   at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
   at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
   at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
   at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
   at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
   at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Client Stack Trace
   at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
   at Erp.Proxy.BO.APAgingTrackerImpl.GenerateTracker(String supplierID)
   at Erp.Adapters.APAgingTrackerAdapter.GenerateTracker(String supplierID)
   at Erp.UI.App.VendorEntry.TrackerTransaction.GetAging()
Hey Ken,
Sometimes a date way in the future is entered accidentally and the aging would push it out further than the fiscal calendar. Maybe run a BAQ of the APInvcHed and checks the dates then compare to the Fiscal Calendar. Also, check to see if a payment term has an unusually large number of net/discount days.
Nothing with a date outside of a date in the FiscalPer Table.
Terms all look good.
This is happening for everyone Supplier so something is not working as expected.
This is a known issue. This feature will not work on the last day of the month.
