Invoice Entry FAIL
Wonderful!
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of Andrew Best
Sent: Wednesday, January 27, 2010 3:08 PM
Subject: RE: [Vantage] Invoice Entry FAIL
Thanks. We think that this might have corrected the issue.
Regards,
Andrew Best
Kice Industries, Inc.
P(316)744-7151
F(316)295-2412
Behalf
Of Blake Clemens
Sent: Wednesday, January 27, 2010 8:14 AM
Have you tried using Invoice Entry in developer mode. Maybe your
ARInvoiceEntry.dll is corrupted. I could send you a copy of our
ARInvoiceEntry.dll You could rename your .dll and copy mine to the
folder to see if it still behaves the same way. We're on the same
version of Vantage.
Also, did you clear out the folder in... C:\Documents and Settings\All
Users\Application Data\Epicor\Vantage Log out of Vantage on any
client PC. Clear out anything that resides in this path. Then log back
into Vantage and try Invoice Entry again.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Andrew Best
Sent: Wednesday, January 27, 2010 9:00 AM
No, we operate most of Vantage as is out-of-the-box. Like I said that
everything has been working fine and then it refused to respond starting
yesterday.
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Behalf
Of Blake Clemens
Sent: Wednesday, January 27, 2010 7:23 AM
We're on 408B and that does not happen. Is your Invoice Entry
customized? If so, try creating a new invoice entry without any
customizations.... this will be the first thing support will ask you.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Andrew Best
Sent: Tuesday, January 26, 2010 5:54 PM
Subject: [Vantage] Invoice Entry FAIL
8.03.408B
We have been on this release for several months. Today, Invoice Entry
suddenly stopped functioning. We rebooted the desktop computers and
Vantage to no avail. Anyone else experience this problem? Invoice
Entry freezes and after several minutes, the users session crashes.
Regards,
Andrew Best
Purchasing
P(316)744-7151
F(316)295-2412
8.03.408B
Regards,
Andrew Best
Purchasing
P(316)744-7151
F(316)295-2412
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Andrew Best
8.03.408B
Regards,
Andrew Best
Purchasing
P(316)744-7151
F(316)295-2412
Any new BPM's perhaps?
Of Andrew Best
Sent: Tuesday, January 26, 2010 4:54 PM
8.03.408B
Regards,
Andrew Best
Purchasing
P(316)744-7151
F(316)295-2412
yesterday.
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Andrew Best
8.03.408B
Regards,
Andrew Best
Purchasing
P(316)744-7151
F(316)295-2412
Andrew
I does this happen when you pull shipment or when you enter other types
of invoices?
Also what do your appserver logs tell you?
Gary
Of Andrew Best
Sent: 27 January 2010 2:00 PM
yesterday.
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Andrew Best
8.03.408B
Regards,
Andrew Best
Purchasing
P(316)744-7151
F(316)295-2412
version of Vantage.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Andrew Best
yesterday.
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Andrew Best
8.03.408B
Regards,
Andrew Best
Purchasing
P(316)744-7151
F(316)295-2412
Have you looked at server activity when this happens?
Are you an SQL backend or a Progress Back End? I am going to guess that you
are a SQL backend.
What happens to your appservers when this happens? I would suspect that they
all become busy and your server starts to create the maximum number allowed
and they all become busy and sit there apparently doing nothing.
First thing you need to do is setup your MfgSys803 appserver for verbose
logging, Set these up on the AGENT, not the BROKER, and make sure you setup
a log file threshold size, I like 5000000 for a size personally, and I
usually put the max number of server log files at something like 10, this
will prevent an infinite number of logs from being created.
When you have a crash, make sure you copy all the logs somewhere before you
restart the appservers, otherwise you run the risk of losing those logs.
If you have this done prior to calling support for anything, since this is
going to be one of the first things they want you to do.
If my suspision and guess from the start of this is correct, then you likely
have some sort of lock that is being created and causing the hangup, first
thing you need to do is cut off anyone and everything that is not your
Vantage server that is using an ODBC connection.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, January 26, 2010 5:53 PM
> 8.03.408B
> Regards,
> Andrew Best
> Purchasing
> P(316)744-7151
> F(316)295-2412
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
No changes at all. We have Epicor now on a new server and are
committing all available resource to testing it. 8.03 hasn't changed
for several months.
We don't use BPM's.
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Of Matt Caldwell
Behalf
Of Andrew Best
8.03.408B
Regards,
Andrew Best
Purchasing
P(316)744-7151
F(316)295-2412
Does it crash just when you double-click Invoice Entry to open the app?
Or is it when you try to open a group? Get shipments?
How far do you get?
Sent: Wed, January 27, 2010 8:13:58 AM
ARInvoiceEntry. dll is corrupted. I could send you a copy of our
ARInvoiceEntry. dll You could rename your .dll and copy mine to the
version of Vantage.
Users\Application Data\Epicor\ Vantage Log out of Vantage on any
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Andrew Best
To: vantage@yahoogroups .com
yesterday.
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
[mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
Behalf
Of Blake Clemens
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
customizations. ... this will be the first thing support will ask you.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Andrew Best
8.03.408B
Regards,
Andrew Best
Purchasing
P(316)744-7151
F(316)295-2412
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Of Blake Clemens
version of Vantage.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Andrew Best
yesterday.
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Andrew Best
8.03.408B
Regards,
Andrew Best
Purchasing
P(316)744-7151
F(316)295-2412
