IO Error
That is correct. Progress install is from 6.0 database. Rather than
reinstall Progress when moving to 6.1 I left it. Each install does
require two mappings.
Sent: Monday, February 21, 2005 11:11 AM
Subject: RE: [Vantage] IO Error
I noticed immediately your executable is looking for
Y:\PROGRESS\bin\prowin32.exe and everything else is V:\mfgsys61 Did you
seperate your progress from vantage on all of your installs thereby
needing 2 drive mappings for each Vantage install?
(Y:\ and V:\)
Sent: Monday, February 21, 2005 10:42 AM
[MFG Startup]
Executable=Y:\
Database=V:\mfgsys61\db\MFGSYS
IniFile=V:\mfgsys61\mfgsys.ini
ParameterFile=V:\mfgsys61\db\mfgsys.pf
ConnectOptions=-N TCP -H entdb2 -S 6100 -ld MFGSYS
TempDirectory=C:\Epicor\MfgWrk61
StartupProcedure=mainmenu.w
OtherParameters=-rand 2 -q -basekey ini mfgsys=VN mfglanguage=enu
mfgtranslator=yes unicode=true ;MFGODBCpasswd=sysprogress
;MFGODBCUser=sysprogress ;MFGODBCDbse=mfgsys ;MFGODBCServer=Progress91D
No, I did not get an uninstall message. I could manually uninstall and
reinstall.
Sent: Monday, February 21, 2005 10:39 AM
the IO error 22 is nebulous and indicates anything from Anti-virus to
massive hardware failure.
But having experienced it I can assure you its related to the
tempdirectory issue ;)
IF you dont mind edit your session/shortcut and paste in a reply.
Did it prompt you to uninstall the progress client before reinstalling?
Sent: Monday, February 21, 2005 10:26 AM
I tried to run the install again on the terminal server and the Vantage
portion of the installation went the way it usually does. The Progress
portion however just disappeared after clicking OK on the screen where
you enter the working directory path. I have never seen that before. I
have reviewed the temp directory path in the Vantage shortcut on the
terminal server and it points to the same path as all other clients(all
of which are working normally). That is the way it has always been
set-up.
Sent: Monday, February 21, 2005 10:17 AM
Does your Vantage TS client install point to a different mfgwork61 temp
directory than your regular clients?
Chances are you ran a recent Vantage install that varies slightly from
your original install... you can correct by editing the .vtg session
file and repoint to the actual mfgwork61... (the same is true regardless
which version of Vantage you're running.)
Sent: Monday, February 21, 2005 8:49 AM
Subject: [Vantage] IO Error
Has anyone seen the following error? Version 6.1.520
SYSTEM ERROR: I/O Error 22 in readit, ret -1, file 9, addr 0 (290)
I am getting this when users try to open Vantage via Terminal Server
session. Click OK and the message and Vantage go away. Support is closed
today. Anyone know how to correct this error?
Todd
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
<http://groups.yahoo.com/group/vantage/files/.> > >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/messages> > >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
<http://groups.yahoo.com/group/vantage/links> > >
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/>
<http://groups.yahoo.com/group/vantage/> >
<http://groups.yahoo.com/group/vantage/> > >
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service < http://docs.yahoo.com/info/terms/
<http://docs.yahoo.com/info/terms/>
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/>
Yahoo! Groups Links
and
_____
Yahoo! Groups Links
<http://docs.yahoo.com/info/terms/> > .
Yahoo! Groups Links
and
Yahoo! Groups Sponsor
<http://us.ard.yahoo.com/SIG=129gp03t8/M=324658.6070095.7083352.3001176/
D=
groups/S=1705007183:HM/EXP=1109086930/A=2343726/R=0/SIG=12impb4jn/*http:
clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=110900053045545
2>
D=
groups/S=1705007183:HM/EXP=1109086930/A=2343726/R=1/SIG=12impb4jn/*http:
2>
Get unlimited calls to
U.S./Canada
<http://view.atdmt.com/VON/view/yhxxxvon01900091von/direct/01/&time=1109
00
0530455452>
<http://us.adserver.yahoo.com/l?M=324658.6070095.7083352.3001176/D=group
s/
S=:HM/A=2343726/rand=199298326>
_____
Yahoo! Groups Links
Service <http://docs.yahoo.com/info/terms/> .
Yahoo! Groups Links
Todd
your original install... you can correct by editing the .vtg session file
and repoint to the actual mfgwork61... (the same is true regardless which
Todd
_____
Yahoo! Groups Links
set-up.
Todd
_____
Yahoo! Groups Links
Yahoo! Groups Links
set-up.
Todd
_____
Yahoo! Groups Links
Yahoo! Groups Links
_____
Yahoo! Groups Links
[MFG Startup]
Executable=Y:\PROGRESS\bin\prowin32.exe
mfgsys=VN
mfglanguage=enu
mfgtranslator=yes
unicode=true
;MFGODBCDbse=mfgsys
reinstall.
set-up.
Todd
_____
Yahoo! Groups Links
Yahoo! Groups Links
and
_____
Yahoo! Groups Links
Yahoo! Groups Links
Did you seperate your progress from vantage on all of your installs
thereby needing 2 drive mappings for each Vantage install?
(Y:\ and V:\)
[MFG Startup]
Executable=Y:\
mfgsys=VN
mfglanguage=enu
mfgtranslator=yes
unicode=true
;MFGODBCDbse=mfgsys
reinstall.
set-up.
Todd
_____
Yahoo! Groups Links
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
Yahoo! Groups Links
and
_____
Yahoo! Groups Links
Yahoo! Groups Links
<http://us.ard.yahoo.com/SIG=129gp03t8/M=324658.6070095.7083352.3001176/D=
groups/S=1705007183:HM/EXP=1109086930/A=2343726/R=0/SIG=12impb4jn/*http://
clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1109000530455452>
groups/S=1705007183:HM/EXP=1109086930/A=2343726/R=1/SIG=12impb4jn/*http://
U.S./Canada
<http://view.atdmt.com/VON/view/yhxxxvon01900091von/direct/01/&time=110900
0530455452>
<http://us.adserver.yahoo.com/l?M=324658.6070095.7083352.3001176/D=groups/
_____
Yahoo! Groups Links
