Iowa State Withholding Tax
Darren -
When I worked for Technical Services, Inc. in Ames, Iowa, on 6.1, I did check the rates & seemed to be close, but they don't round to nearest $ as recommended, nor as required for federal withholding, which I sent them the tax booklets for Federal & State that noted as such. Requested probably over a year ago, and as of June, when I left Technical Services, Inc., even that wasn't fixed. I would definitely call in to Epicor, and possibly see if there is any maintenance or updates that may fix your issue. I put the request for tax fix on payroll in on both 6.1 and 8 versions at the time. I have knowledge that very few, 10% or less of their clients use their payroll system, as well, so that may impact their fix rate, although I would think that IRS potential complaints would as well.
- Becky Venneman, CMA, SPHR
Accounting, Human Resources, Website Design, Hosting & Marketing, & Crystal Consultant
becky.venneman@...
Owner, Virtual Bizniz
info@...
----- Original Message -----
To: Vantage User Group (vantage@yahoogroups.com)
Sent: Monday, September 25, 2006 12:06 PM
Subject: [Vantage] Iowa State Withholding Tax
Has anyone taken the time to manually calculate the state withholding to
check it with Vantage? We just had an employees complain that they got a
raise and they got only $6 of it on their check. So we started digging into
it and the state taxes rose from 33.04 to 49.90, while the fed taxes only
went up 94.50 to 100.38. I calculate the taxes manually and state taxes
should have been 41.36 before the raise and 43.61 after. We pay weekly and
this person has an extra $8.50 taken out for state taxes with 0 exemptions.
Any suggestions. I've double checked the tax tables and they are keyed
correctly. Vantage version 5.1
Darren Mann
IT Manager
Miller Products Co.
1015 N. Main St.
Osceola, IA 50213
Ph. 641-342-2103
Fax 641-342-3222
Darren Mann
IT Manager
Miller Products Co.
1015 N. Main St.
Osceola, IA 50213
Ph. 641-342-2103
Fax 641-342-3222
