Irregular Size Inventory Input into MRP
Are any companies using Kinetic to inventory irregular shaped material such as stone slabs?
Knowing the irregular shape of each slab and the remaining on hand after a slab is cut or sheared?
How do you know that the demand size you need could be satisfied w/ existing inventory?
I.E. Inventory is by lbs. and it could say you have 3000 or by sqft - but which might consist of 10 pcs w/ dimensions that don’t fit what you need
Are you using anytype of system to compare a rectangle w/ dimensions against graph, draft files, or photoes of slab inventory to see if there is a hit and if not that would drive MRP?
