Is a client reinstall required after making changes to the application server?
Question’s in the subject! I am working on the rollout of a new Kinetic environment and find myself constantly making changes to the different environments, which also updates the client config. Do I need to re-push the software to my users after making these changes? Or, will making a change force an update on clients that are already installed?
Thanks!
Depends on the change
It would be a change to the authentication method(to Epicor Basic)
Alex Fishel
Network Engineer
Alex​
Fishel
Project Engineer
O: (309) 662-7723 | D: (309) 664-8154
E: afishel@integrityts.com | W: integrityts.com
816 S. Eldorado Road, Suite 4
​Bloomington, IL 61704
Facebook
Instgram
LinkedIn
Twitter
This message contains confidential information and is intended only for the intended recipients. If you are not an intended recipient you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. E-mail transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender therefore does not accept liability for any errors or omissions in the contents of this message, which arise as a result of e-mail transmission. If verification is required please request a hard-copy version. v03232016
No that doesn’t trigger an update.
