We found our problem....turns out that there's an older 'Epicor
Crystal runtime' that was still installed, and was not manually
removed when we installed the latest one. After removing both, then
re-installing the latest one...all's well. Sometimes, it's the most
obvious problems that are the hardest to find...!
Gary
Gary
--- In vantage@yahoogroups.com, "Gary Franks" <garyfr2003@...> wrote:
> Actually, we've tried uninstalling everything, then re-installing, but
> no joy, unfortunately....Gary
> --- In vantage@yahoogroups.com, "Charlie Wilson" <foamdesigncsw@>
> wrote:
> > By chance do you have both the old 1.1 runtime and the 3.0 runtime
> on these
> > machines?
> > _____
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf Of
> > Gary Franks
> > Sent: Tuesday, December 09, 2008 11:29 AM
> > Subject: [Vantage] Is anyone having trouble with Crystal PROMPTS
> when using
> > runtime with XP ?
> > Everything works great with Vista clients, but any time we run several
> > of our Customized Crystal Reports on XP workstations, the PROMPTS that
> > we've designed within these specific reports do not work correctly.
> > Can't uninstall the latest runtime and try the older version, as the
> > uninstall routine really doesn't remove everything.
> > I'm hoping that someone may have already gone through this and perhaps
> > have an answer......The kind folks at the Epicor HelpDesk haven't yet
> > been able to find the root cause of this.
> > For the record, we are using the 3_05_2008 version of the runtime,
> > with Vantage 8.03.405a.
> > Thanks....Gary
> > No virus found in this incoming message.
> > Checked by AVG - http://www.avg.com
> > Version: 8.0.176 / Virus Database: 270.9.15/1837 - Release Date:
> 12/9/2008
> > 9:59 AM
