Is it possible to add "Where Used" from part maint to the part
Thanks, your the best!
DaveO
--- In vantage@yahoogroups.com, Amy OMalley <omall004@...> wrote:
> I'm assuming you are on 8.0
> It is in Part Tracker under the Action pull down menu
(unfortunately,
> currently not on the right click like in part maintenance)
> Amy O'Malley
> Manufacturing Engineer
> Synovis IS
> 8.00.811
> On Sep 17 2007, Dave Olender wrote:
> >There is a program available from the part maintenance if you
right
> >click on the part number field called "Where Used". I would like
to
> >know if it's possible to add that to the Part Tracker?
> >Has anyone tried this already, or have any suggestions.
> >Thanks
> >DaveO
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
must
> > have already linked your email address to a yahoo id to enable
access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/. (2) To search
through old
> > msg's goto: http://groups.yahoo.com/group/vantage/messages (3) To
view
> > links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links Yahoo! Groups Links
> Amy O'Malley
> Minneapolis, Minnesota, USA
> omaLL004@...
There is a program available from the part maintenance if you right
click on the part number field called "Where Used". I would like to
DaveO
Try this. Create A button, go to the wizard and create a Click event.
Then paste this in:
Otrans.WhereUsed("")
When you are on a part click it and it should launch the where used
with the correct data.
> Thanks
> DaveO
There is a document # 6388mps that you can get from support that explains
how to modify the "Context Menu". The only problem is that there is a bug
with the modification that you will have to ask for the steps to deploy the
change to all of the clients.
Steve
Sent: September 17, 2007 11:30 AM
Subject: [Vantage] Is it possible to add "Where Used" from part maint to the
part tracker?
DaveO
It is in Part Tracker under the Action pull down menu (unfortunately,
Amy O'Malley
Synovis IS
8.00.811
>Thanks
>DaveO
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/files/. (2) To search through old
> msg's goto: http://groups.yahoo.com/group/vantage/messages (3) To view
Amy O'Malley
omaLL004@...
