Is the Check Register a Crystal Report?
I was afraid of that. Thanks for the info.
Reggie
--- In vantage@yahoogroups.com, "Ross Hughes" <ross.hughes@...> wrote:
> It is not a Crystal Report. You will need to rebuild it from scratch if you
> want to make edits to it. Either that, or have Epicor edit it....unless you
> have the SDK.
> It is pretty straight forward. Mostly the Checkhed, Vendor and BankAcct
> tables. If you need the void date on the report you may have to reach
> across to the APTran table.
> Ross
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> bjcracosta
> Sent: Monday, April 20, 2009 7:13 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Is the Check Register a Crystal Report?
> I've been tasked with adding a couple of columns to the check register
> (payment register) report. However, I haven't been able to find a crystal
> report for it.
> Prog: APR30 prints at the upper left corner of the report. Does this mean
> it's not a crystal report? How do I change it if it isn't a crystal report?
> Thanks,
> Reggie Acosta
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
I've been tasked with adding a couple of columns to the check register (payment register) report. However, I haven't been able to find a crystal report for it.
Prog: APR30 prints at the upper left corner of the report. Does this mean it's not a crystal report? How do I change it if it isn't a crystal report?
Reggie Acosta
have the SDK.
Ross
bjcracosta
report for it.
Reggie Acosta
