Is there a better Query than Microsoft Query
One of my favorites is Aqua Data Studio, Works really well.
http://www.aquafold.com/ <BLOCKED::http://www.aquafold.com/>
Dave Huddleston
CIO Bruewer Woodwork
Cincinnati, Ohio
_____
bakerprovan
Sent: Tuesday, November 07, 2006 7:09 AM
Subject: [Vantage] Is there a better Query than Microsoft Query
I extract data from Vantage into Excel using Microsoft Query. It
works OK as long as you keep things simple but I am getting tired of
working around the shortcomings when things get a bit more involved.
For instance you can't use outer joins when working with more than 2
tables.
Does anyone out there know of a better tool for getting the data into
excel? I am an occasional user of these features and prefer to avoid
SQL if I can.
Regards
Bob Findlay
tables.
SQL if I can.
Regards
Bob Findlay
you can set up an ODBC connection using MS Access. Link your tables and
then create your query
there. It works pretty good.
Of bakerprovan
tables.
SQL if I can.
Regards
Bob Findlay
I use MS Access, it also has constraints when using multiple joins but
all you have to do is create multiple queries (query of a query) and the
problem is resolved.
When finished, all you need to do is create a macro that will export
your results to excel.
Gerard M Wadman
Sr. Network Systems Engineer
Scandius BioMedical Inc.
11A Beaver Brook Road
Littleton, MA 01460
978/486-4088 x 124
978/486-4108 (fax)
http://www.scandius.com/
Of bakerprovan
tables.
SQL if I can.
Regards
Bob Findlay
