Is there a field in PartTran file (or other linked file) that ma
Good Day Dale:
To my surprise, for many PartTran records BeginQty and EndQty are
zero.
That is because, as the data dictionary explains: """"On Hand
Quantity before the part costing calculations were run""". So STK-CUST
is all zero's because the cost is not changed ( averaged).
Thanks for the suggestion though.
len.hartka@...
Of Dale
Sent: Monday, March 12, 2012 9:01 AM
Subject: [Vantage] Re: Is there a field in PartTran file (or other
linked file) that marks the Transaction as affecting inventory?
There is nothing that I know of. I have never tried the following but
some possible ideas:
1 Select records on BeginQty not equal to AfterQty
2 Create a BPM(may be more than one) that stores the Difference between
BeginQty and AfterQty in a number field. Then select if Number not equal
to zero.
Hope this helps
Dale
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Len
Hartka" <len.hartka@...> wrote:
> Good Day:
> Is there a field in PartTran file (or other linked file) that marks
> There is Tran-Type- STK-CUS, STK-MTL, etc, but there are many that
> affect the QOH.
> There is Tran-Class - A,D,I etc - that lump Tran-Types together, but
> not in the correct way.
> What I want is a field, with one value that will limit the PartTran
> records to ones that affect QOH. I can them sum up the changes and get
> the detail of Inventory Value change.
> What I need it for is a BAQ for the PartTran file which will limit
> the records to ones that change the QOH, then prompt for a range of
> dates, so I can find out why inventory went up in February by Part#.
> I just did it by using Stock-Status for 2/1 ( actually 1/31 end of
> day) and 2/28; but comparing is difficult because each list has
Part#'s
> the other does not which leads to "Null" ( not zero) values which
ACCESS
> and Excell have real problems with.
> Leonard C. Hartka, IT Director\ERP Manager
> Sun Automation Group
> 66 Loveton Circle
> Sparks, Md. 21152
> 410-329-3560 ext. 120
> 410-329-3564 FAX
> 443-255-7192 Work Cell
> len.hartka@...
> Celebrating More Than
> 20 Years of Service
> to the Corrugated Industry
> This e-mail and any attachments may contain proprietary and/or
confidential information. If you are not the intended recipient, please
notify the sender immediately by reply e-mail or at 410-472-2900 and
then delete the message without using, disseminating, or copying this
message or any portion thereof. With e-mail communications you are urged
to protect against viruses.
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
Good Day:
affect the QOH.
day) and 2/28; but comparing is difficult because each list has Part#'s
the other does not which leads to "Null" ( not zero) values which ACCESS
66 Loveton Circle
Sparks, Md. 21152
410-329-3564 FAX
len.hartka@...
20 Years of Service
There is nothing that I know of. I have never tried the following but some possible ideas:
2 Create a BPM(may be more than one) that stores the Difference between BeginQty and AfterQty in a number field. Then select if Number not equal to zero.
Hope this helps
Dale
--- In vantage@yahoogroups.com, "Len Hartka" <len.hartka@...> wrote:
> Good Day:
> affect the QOH.
> 66 Loveton Circle
> Sparks, Md. 21152
> 410-329-3564 FAX
> len.hartka@...
> 20 Years of Service
I don't know the answer to your question as you have asked it, but I do know of a solution in Excel. You can write your formula using IFERROR to eliminate errors. For example, if your formula is dividing cell B1 by cell C1, you would enter =IFERROR(+B1/C1,0)
Another solution would be to use conditional formatting and highlight cells with errors. You would then need to sort on those cells to eliminate them; an extra step, I know, but it does work.
Kay Doolin
Indaco Metals LLC
kay.doolin@...
> Good Day:
> affect the QOH.
> 66 Loveton Circle
> Sparks, Md. 21152
> 410-329-3564 FAX
> len.hartka@...
> 20 Years of Service
