Is there a way to check and see who unapproved a part?
We had an issue today where a part that wasn’t supposed to, got unapproved. I would like to know if there is a way to tell who unapproved it so that we can implement some additional training where/if required.
Thanks for any help/information.
Not unless you have change logs enabled… Do you?
We didn’t before the change, we do now!
How do you enable change logs?
Change logs… create a DATA BPM and specify the fields you want to log… WARNING, do not log EVERY field in every table.
  • Good examples are:
  • Part Description, Part approval, etc
  • Customer credit hold & credit limits
Bad Examples:
  • Last change date in any table (change logs already track this)
  • anything that is automatically generated in mass by a system function:
    ** JobMtl, JobOpr, etc values when the job is not firmed (MRP manipulates JobMtl values, and so you get millions of change log entries if not careful. You can create a “Filter” to say to only log entries for specific user groups)
