Is there a way to point an Attachment Link at a Network folder?
That worked! Thanks!
Regards,
Chris Wineinger
ERP Specialist
Interior Systems, Inc. <http://www.isiamerica.com/>
241 N Broadway Ste 600
Milwaukee, WI 53202
Office # 414.224.0957 X2051
Direct# 414.847.0701
Cell # 414.840.6594
Instead of linking 8-10 documents & pictures to a job, is there a way to put in an attachment link that points to a folder on the network that contains all the files for the job?
Chris Wineinger
ERP Specialist
Interior System Inc
Yes, but not easily. It worked better in Vantage 6, its possible but a
multi-step process in 9.05.
Create a new Document Association with extension \ (yes, just a
backslash) and view command of: explorer.exe "&1"
Attach a single document in the folder you want - it will create a link
to eg X:\Stuff\whatever.PDF
In External File Reference, find that link (it will be the highest#) and
change the filename to X:\Stuff\
Now opening that attachment will open windows explorer right at that
folder.
Brian.
Of redrhyno13
Sent: Friday, June 22, 2012 11:30 AM
Subject: [Vantage] Is there a way to point an Attachment Link at a
Network folder?
Chris Wineinger
ERP Specialist
Interior System Inc
Chris,
I was working on a different way of doing this thru a BUTTON added as a
form customization which would dynamically read the Job Number and path
you to that folder name using Explorer.exe. Then you would not have to
create a DUMMY link with each job.
Vantage 6.1
Customize the Part Tracker Screen, Add a Button
SHELLEXEC explorer.exe /root,
S:\{CustNo.Scrvalue}\{Part.SearchWord.Scrvalue}
Epicor9
Customize say the Job Tracker Screen, Add a Button
"Open the Job Folder"
Process.Start ("explorer.exe", "/root, S:\")
Sorry, this is as far as I got. I didn't figure out the
dynamic part of inserting the Job Number from the form.
Patrick Winter
Of Brian Roberts
Sent: Friday, June 22, 2012 12:26 PM
Subject: RE: [Vantage] Is there a way to point an Attachment Link at a
Network folder?
folder.
Brian.
Behalf
Of redrhyno13
Network folder?
Chris Wineinger
ERP Specialist
Interior System Inc
