Is there a way to set PO receipts to always default to received rather than arrived?
I think I have seen it before, but I can’t seem to find it when I need to of course. Is this a setting I can make, or will it be a BPM?
I thought that when using the “Actions → Mass Receipt”, the releases are marked as “received” instead of “arrived”?
Guessing you’ll need a BPM if you If you receive each release manually.
