When you select a Reusable Combo, a lot of the fields default in and cannot be edited. I would like to either change the sort or add to it.
Anyone know of a way? @hmwillett
Type it all in yourself without filling out the first 2 fields.
But why does it not sort integers correctly??
Specifically, to make you rage.
Probably.
Probable cause: working as designed. But fear not - it gives you the opportunity to open a case on the new EpicCare site to report the issue.
