Thanks Steven, I remember stumbling across this some time back but today I could not remember it. Brain fade.
Thanks for your help.
George
George
--- In vantage@yahoogroups.com, Steven Gotschall <sgotschall@...> wrote:
> That is a good question that I found an answer to by accident a few weeks ago when I was talking to Epicor support.
> Â
> Open the System Agent and navigate to your Process MRP task. In the Actions menu select "View Task Parameters". You can view the settings here, but you can't change them. Well, you can change them and then save it which will cause a new task to be created, and then if you want to you can delete the old task.
> From: pcivantage <pcivantage@...>
> To: vantage@yahoogroups.com
> Sent: Wed, October 14, 2009 3:14:00 PM
> Subject: [Vantage] Is there a way to view Scheduled Task process parameters in 8.03.408
> Â
> I have several scheduled tasks to run MRP at different times with different parameters for the task. Is there a way to view the details of what will be passed to the MRP run that are contained in the scheduled task? Of course you can view the start, end, time and recurring params, but how about the actual values like Net Change or Regen?
> Regards,
> George Hicks
