Is there any Audit Log in Engineering Wrokbench
Normaly when we do audilt log we have to create a table to record the
changes.
is it possible to do it via BAQ?
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
wrote:
> Yes. It's in v8. Make sure you didn't menu edit yourself out of
access to it. (Easy to do.)
> Rob
> --- On Sat, 12/20/08, mintokmint <mintokmint@...> wrote:
> From: mintokmint <mintokmint@...>
> Subject: [Vantage] Re: Is there any Audit Log in Engineering
Wrokbench
> To: vantage@yahoogroups.com
> Date: Saturday, December 20, 2008, 10:51 AM
> Business active Managment?
> is it avaliable in 800?
> --- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...>
> wrote:
> > Engineering WorkBench (Eng WB).
> > As I said, audit logs are BAM driven so, even though the app
> doesn't natively provide for a view change long Action, it doesn't
> mean you can't still set up a BAM to collect the change data (and
> then view another way: BAQ/dashboard, Crystal, a VB customization
to
> Eng WB).
> > Rob
> > --- On Thu, 12/18/08, mintokmint <mintokmint@ ...> wrote:
> > From: mintokmint <mintokmint@ ...>
> Wrokbench
> > To: vantage@yahoogroups .com
> > Date: Thursday, December 18, 2008, 9:24 AM
> > What do mean by Eng WB?
> > Is there any possible to do that Audit Log for BOM change?
> > Many thanks
> > wrote:
> > > I think I lead you astray folks. I was relying on my (faulty!)
> > memory when I replied.
> > > Eng WB seems to be one of the few apps without a view change
log
> > option in the Actions menu. We log critical fields in Part Entry
> (as
> > well as order/job/PO entry).
> > > The whole process is BAM driven. That being so, it may still be
> > possible to log changes to the table data Eng WB can edit.
> > > The trick would then be providing a way to VIEW the log data.
> > > With VB customization, I think that would be possible... Just
> > perhaps not very elegant from a standard UI perspective.
> > > Rob
> > > --- On Tue, 12/16/08, Hernandez, Dolores <dhernandez@ ...>
wrote:
> > > From: Hernandez, Dolores <dhernandez@ ...>
> > > Subject: RE: [Vantage] Re: Is there any Audit Log in
Engineering
> > Wrokbench
> > > Date: Tuesday, December 16, 2008, 5:11 PM
> > > I would also like to know how to do this for any table.field
> > > From: vantage@yahoogroups .com [mailto:vantage@
yahoogroups .com]
> On
> > Behalf
> > > Of mintokmint
> > > Sent: Tuesday, December 16, 2008 4:59 AM
> > Wrokbench
> > > How can i do that?
> > > --- In vantage@yahoogroups .com <mailto:vantage% 40yahoogroups.
> > com> ,
> > > wrote:
> > > > You can set up change logging on any table.field from the
> > > appropriate editing apps (in your case - Engineering WB).
> > > > Don't go too crazy though as it there is overhead associated
> with
> > > it (and it can slow down application speed).
> > > > Rob
> > > > Subject: [Vantage] Is there any Audit Log in Engineering
> Wrokbench
> > > > To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups.
> com>
> > > > Date: Tuesday, December 16, 2008, 1:37 AM
> > > > I want to check the who and how to change the BOM.is
> > > there any audit
> > > > log in Engineering workbench?
> > > > Any advise?
> > > > many thanks
I want to check the who and how to change the BOM.is there any audit
Any advise?
many thanks
You can set up change logging on any table.field from the appropriate editing apps (in your case - Engineering WB).
Don't go too crazy though as it there is overhead associated with it (and it can slow down application speed).
Rob
--- On Tue, 12/16/08, mintokmint <mintokmint@...> wrote:
Subject: [Vantage] Is there any Audit Log in Engineering Wrokbench
Any advise?
many thanks
How can i do that?
> Rob
there any audit
> Any advise?
> many thanks
Without using the Change log, the system automatically tracks what you
do AS LONG AS you record it. The system then captures the date, time,
user and note they put in. Of course this assumes the user has to
actually add the notes, this is the only drawback.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of mintokmint
Sent: Tuesday, December 16, 2008 12:38 AM
Any advise?
many thanks
Of mintokmint
Subject: [Vantage] Re: Is there any Audit Log in Engineering Wrokbench
How can i do that?
> Rob
there any audit
> Any advise?
> many thanks
I think I lead you astray folks. I was relying on my (faulty!) memory when I replied.
Eng WB seems to be one of the few apps without a view change log option in the Actions menu. We log critical fields in Part Entry (as well as order/job/PO entry).
The whole process is BAM driven. That being so, it may still be possible to log changes to the table data Eng WB can edit.
With VB customization, I think that would be possible... Just perhaps not very elegant from a standard UI perspective.
Rob
--- On Tue, 12/16/08, Hernandez, Dolores <dhernandez@...> wrote:
Subject: RE: [Vantage] Re: Is there any Audit Log in Engineering Wrokbench
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of mintokmint
How can i do that?
--- In vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ,
> Rob
> To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
there any audit
> Any advise?
> many thanks
Many thanks
> Rob
> From: Hernandez, Dolores <dhernandez@...>
Wrokbench
Behalf
> Of mintokmint
Wrokbench
> How can i do that?
com> ,
> > Rob
> there any audit
> > Any advise?
> > many thanks
As I said, audit logs are BAM driven so, even though the app doesn't natively provide for a view change long Action, it doesn't mean you can't still set up a BAM to collect the change data (and then view another way: BAQ/dashboard, Crystal, a VB customization to Eng WB).
Rob
Many thanks
> Rob
Wrokbench
> From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On
Behalf
> Of mintokmint
Wrokbench
> How can i do that?
com> ,
> > Rob
> there any audit
> > Any advise?
> > many thanks
Eng WB).
> Rob
Wrokbench
> Many thanks
(as
> > Rob
> Wrokbench
On
> Behalf
> > Of mintokmint
> Wrokbench
> > How can i do that?
> com> ,
with
> > > Rob
Wrokbench
com>
> > there any audit
> > > Any advise?
> > > many thanks
Yes. It's in v8. Make sure you didn't menu edit yourself out of access to it. (Easy to do.)
Rob
Eng WB).
> Rob
Wrokbench
> Many thanks
(as
> > Rob
> Wrokbench
On
> Behalf
> > Of mintokmint
> Wrokbench
> > How can i do that?
> com> ,
with
> > > Rob
Wrokbench
com>
> > there any audit
> > > Any advise?
> > > many thanks
