Is There any Field that record the Oringal jobnum when Split it
You can check the data dict. If it's there it would be in the labordtl.
In thinking about the question, the system creates adjustments when
splitting jobs (negative to the split from and positive to the split to)
so I am going to surmise the answer is no. It is a WIP transaction (and
therefore inventory transaction) so I believe that again, the answer is
no.
Charlie Smith
2W Technologies LLC / Smith Business Services
Of Robert Brown
Sent: Sunday, December 21, 2008 11:21 PM
Subject: RE: [Vantage] Is There any Field that record the Oringal jobnum
when Split it
Charlie,
Good to know for future reference. Would you happen to know if the same
is true of LaborDtl? (That would, by far - if true, be potentially more
useful to us as a result of our own little twist on the job management
process.)
Thx
Rob
--- On Sun, 12/21/08, CharlieSmith <CSmith@...
when Split it
Date: Sunday, December 21, 2008, 8:59 PM
When a job is split, the current costs are split as well. The PartTran
has those transactions and has two job numbers, the job that was split
and the split job. If the job has no activity on it, you would probably
have a problem chasing it down, but check the PartTran to make sure.
Charlie Smith
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
Of mintokmint
Sent: Sunday, December 21, 2008 9:25 AM
To: vantage@yahoogroups .com
Subject: [Vantage] Is There any Field that record the Oringal jobnum
when Split it
When i spilt a job i want to check the orginal jobnum for the new job
is there a field record it?
I don't think so (but honestly not positive). If you change logging enabled on the right fields that may be your only audit trail.
Rob
--- On Sun, 12/21/08, mintokmint <mintokmint@...> wrote:
Subject: [Vantage] Is There any Field that record the Oringal jobnum when Split it
Date: Sunday, December 21, 2008, 9:24 AM
Charlie Smith
Of mintokmint
when Split it
Charlie,
Good to know for future reference. Would you happen to know if the same is true of LaborDtl? (That would, by far - if true, be potentially more useful to us as a result of our own little twist on the job management process.)
Thx
Rob
--- On Sun, 12/21/08, CharlieSmith <CSmith@...> wrote:
Subject: RE: [Vantage] Is There any Field that record the Oringal jobnum when Split it
Charlie Smith
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of mintokmint
when Split it
