Is this a bug in 9.05?
I wonder why it isnt working in our DB in 505c.
Any suggestions?
Sent: Mon, 15 November, 2010 13:33:23
Subject: RE: [Vantage] Is this a bug in 9.05?
Â
Just tested that in 9.04.505c and it works correctly. Not the answer to your
question but might help.
Chris Thompson
Sent: 15 November 2010 11:44
Subject: [Vantage] Is this a bug in 9.05?
In 9.05, if you go into Report Maintenance > Then click the button to search >
Then locate OrderAck > Press OK.
Does it load in ALL of the reports instead of just the one you want??
This happens with me with ...
“1099”, “SOPick”, “OrderAck”, “PackSlip”
... in 505c
Chris HenzelEpicor 9 Project ManagerTel: +44 (0)1582 436150Mob: 07836 314164
This message contains confidential information and is intended only for the
intended recipients. If you are not an intended recipient you should not
disseminate, distribute or copy this email. Please notify the sender if you have
received this email by mistake and delete it from your system.Email transmission
cannot be guaranteed to be secure or error-free as information could be
intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain
viruses. The sender does not accept liability for any errors or omissions in the
contents of this message, which arise as a result of email transmission.
Registered Office: Hayward Tyler Ltd, 1 Kimpton Road, Luton, LU1 3LD, England.
Tel: +44 (0)1582 731144. Company No. 3450138.
Â
Â
... in 505c
Just tested that in 9.04.505c and it works correctly. Not the answer to your question but might help.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chris Thompson
... in 505c
This message contains confidential information and is intended only for the intended recipients. If you are not an intended recipient you should not disseminate, distribute or copy this email. Please notify the sender if you have received this email by mistake and delete it from your system.Email transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender does not accept liability for any errors or omissions in the contents of this message, which arise as a result of email transmission. Registered Office: Hayward Tyler Ltd, 1 Kimpton Road, Luton, LU1 3LD, England. Tel: +44 (0)1582 731144. Company No. 3450138.
