Can anyone who has upgraded to 8.0 tell me it was worth it?
Did you do it yourself?
Was the support from Epicor helpful?
--- In vantage@yahoogroups.com, "Bruce Butler" <bbutler@...> wrote:
> My best suggestion would be to check how you are linking the
tables. As a simple example;
> Looking for all parts with current open orders
> Assumptions: Orderhed as 100 records, Orderdtl has 500 records, 25
open orders.
> If you setup Orderdtl as the main table, you will look at all
records in Orderdtl, and all records in Orderhed only picking those
where Orderhed is open. Therefore, you would have to look at 500 x
100 records.
> If you setup Orderhed as the main table, it would first look to see
if it was an open order, and, if so, pull the required records. At
the very most you would only have to look at 25 x 500 records cutting
your search time by ¼. Most likely of those 500 Orderdtl records
some would not have to be extracted as they belong to closed orders.
> I know this is rudimentary, but is one that still catches me every
now and then.
> Bruce Butler
> IT Manager
> Knappe & Koester, Inc.
> _____
Behalf Of Dan Ernst
> Sent: Tuesday, December 12, 2006 10:19 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Dashboards - Vantage 8.0
> I have created a dashboard that is accessing the Orderhed table and
the
> PCinvalue table. I have a configured part that has a top, middle
and
> bottom color so I want to be able to display those colors on a
> dashboard. I have been able to do that but it seems to take about
20
> minutes for all the information to display. Does anyone know what I
can
> do to speed up this process?
> Thanks
> Dan Ernst
> Correct Craft, Inc.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Bruce Butler" <bbutler@...> wrote:
open orders.
100 records.
now and then.
> Bruce Butler
> IT Manager
> _____
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf Of Dan Ernst
the
and
20
can
> Thanks
> Dan Ernst
> Correct Craft, Inc.
