I’ve created an external program to issue material, however, in the Part Transaction History the User name is always the same.
I have a dropdrop list containing active employees where you select your name.
How would I change the Part Transaction History User ID to the name selected by the user?
I am assuming you are calling an API? With that you are accessing Epicor with one user. You could override the field with the Epicor username or make a custom field and pass the Epicor username that way as well.
