Dear all kindly need your advice since I am very newbie here. I tried find solution but no luck. I need to create module that auto generate child based on parent table reference in UD109A with this code.
UD109Adapter adapterUD109 = new UD109Adapter(this.oTrans);
adapterUD109.BOConnect();
string parentKey1 = "TestPK1";
string parentKey2 = string.Empty;
string parentKey3 = string.Empty;
string parentKey4 = string.Empty;
string parentKey5 = string.Empty;
bool result = adapterUD109.GetaNewUD109A(parentKey1, parentKey2, parentKey3, parentKey4, parentKey5);
int rowCount =adapterUD109.UD109Data.UD109A.Rows.Count;
DataRow edvUD109ARow = adapterUD109.UD109Data.UD109A.Rows[(rowCount-1)];
edvUD109ARow.BeginEdit();
edvUD109ARow["Company"] = "EPIC06";
edvUD109ARow["Key1"] = parentKey1;
edvUD109ARow["Key2"] = parentKey2;
edvUD109ARow["Key3"] = parentKey3;
edvUD109ARow["Key4"] = parentKey4;
edvUD109ARow["Key5"] = parentKey5;
edvUD109ARow["ChildKey1"] = "PartNum";
edvUD109ARow["ChildKey2"] = "JobNum";
edvUD109ARow["ChildKey3"] = "ASM";
edvUD109ARow["ChildKey4"] = string.Empty;
edvUD109ARow["ChildKey5"] = string.Empty;
edvUD109ARow["RowIdent"] = "A";
edvUD109ARow.EndEdit();
edvUD109ARow.AcceptChanges();
adapterUD109.UD109Data.AcceptChanges();
adapterUD109.Update();
oTrans.Update();
// Cleanup Adapter Reference
adapterUD109.Dispose();
But the compile status keep say that
Error: CS1061 - line 1389 (2599) - ‘Ice.Adapters.UD109Adapter’ does not contain a definition for ‘GetaNewUD109A’ and no extension method ‘GetaNewUD109A’ accepting a first argument of type ‘Ice.Adapters.UD109Adapter’ could be found (are you missing a using directive or an assembly reference?)
kindly need your advice for this. Thanks.
