There are two types of drop downs in the customization toolbox - whichever one you used, try the other one.
The other thing you could try is creating a User Code (under Utilities) for this field and then setting up extended properties on the ud field so that it is linked to your user code - can't remember the exact process here.
--- In vantage@yahoogroups.com, "clederer@..." <clederer@...> wrote:
> I created a drop down box with 3 choices of text to choose from a string array. I recently found out that the user can create their own text and save it instead of using the predefined text from the drop down box. How can I make the predefined text restricted to the values that are created?
