Issue with Updateable BAQ in JobHeader Table
Hi everyone,
I’m encountering a critical issue while using an Updateable BAQ to update two UD fields in the JobHeader table.
Details:
  • I created a simple Updateable BAQ to update two fields in the JobHeader.
  • After entering the desired values and running the BAQ, the system confirms that the process was completed successfully.
  • However, after refreshing the screen:
    • The fields I tried to update remain unchanged.
    • The PartNum field in the table gets unexpectedly deleted.
This behavior is highly concerning.
Has anyone experienced anything similar or found a solution for this?
