I’m in the process of installing 10.2.600 on a new vm (upgrading from 400), and I’m getting many “object reference…” errors while verifying customizations via customization maintenance.
generally followed by
After hitting “Verify All”, I have to click through these errors many times. It’s a little concerning seeing this many errors, but it looks like the customization are still working as far as I’ve tested.
Has anyone else experienced these errors or have any idea why I’m getting them?
I’m also wondering about the “Valid For” field in customization maintenance. I see that it prepends a “w” to the version when there is a warning:
What does the “f” prepended to the version of a passing customization indicate?
It seems to be related to the MES customizations. What’s strange is I created a new customization on MES without anything added to it, and it is still throwing those errors when I verify it.
Gotcha, that makes sense. I went back and tried to verify a blank/no-code MES customization in versions 10.2.300 and 10.2.400 for testing purposes, and got a new error:
Application Error
Exception caught in: Ice.Lib.EpiClientLib
Error Detail
Message: Object reference not set to an instance of an object.
Program: Ice.Lib.EpiClientLib.dll
Method: ConfigureXxxDefRowStandardColumns
Client Stack Trace
at Ice.Lib.Customization.CustomizationVerify.ConfigureXxxDefRowStandardColumns(XXXDefRow defRow, VerifyCustomizationContext verifyContext, String validationMessage)
at Ice.Lib.Customization.CustomizationVerify.TestCustomization(XXXDefRow defRow, VerifyCustomizationContext verifyContext, TimeSpan timeSpan)
Not sure what the effects of the errors are since the customizations are working and the customization maintenance screen claims they pass (without prepending the “f” to the version). I went ahead and opened a support case.
