What is the best way to iterate through a dashboard assembly grid or dataview in an E9 dashboard?
I can access grids through the common method of creating a object from the GUID in E10 (like below) but this is giving me an 'object instance…" error in E9.
Ultimately, I am trying to query a dataset, return it to the grid and then loop through that dataset to perform other operations.
Thank you!
Ross
// Custom code for MainController
// Created: 4/23/2019 9:55:49 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
// ** Wizard Insert Location - Do Not Remove ‘Begin/End Wizard Added Module Level Variables’ Comments! **
EpiUltraGrid ugrdPDPAttachments;
ugrdPDPAttachments = (EpiUltraGrid)csm.GetNativeControlReference("267c0139-0f07-4cb3-8567-1612e4b3c824");
this.ugrdPDPAttachments.DoubleClickRow += new Infragistics.Win.UltraWinGrid.DoubleClickRowEventHandler(this.ugrdPDPAttachments_DoubleClickRow);
this.ugrdPDPAttachments.DoubleClickRow -= new Infragistics.Win.UltraWinGrid.DoubleClickRowEventHandler(this.ugrdPDPAttachments_DoubleClickRow);
// Begin Custom Code Disposal
// End Custom Code Disposal
